coolant mixing with engine oil
Old Oct 9, 2008 | 10:43 AM
hkboy87's Avatar
Default coolant mixing with engine oil
My gf POS american car is messing up badly. Her coolant keeps getting low so we checked it out and it seems that her coolant is mixing or leaking into the engine oil somehow.
What could be the general cause of these mixing together?
Old Oct 9, 2008 | 10:45 AM
SinsEvil666's Avatar
Isssssh....bad news.......Its the headgasket, needs to be replaced
Old Oct 9, 2008 | 10:47 AM
sageuvagony's Avatar
Default Re: (SinsEvil666)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SinsEvil666 &raquo;</TD></TR><TR><TD CLASS="quote">Isssssh....bad news.......Its your headgasket..</TD></TR></TABLE>
Like the Devil said, it's your head gasket 100%
I've been through 3 headgaskets on the same engine till I finally decided to trash the POS. It started off as what you described, then ended up like this
http://www.youtube.com/watch?v=4OV_QD_yFlo
That's my car YEARS ago with the old engine.
hkboy87's Avatar
so would replacing just the headgasket and try flushing out all the mixture gunk in the engine work?
Old Oct 9, 2008 | 10:50 AM
instrument's Avatar
replace the head gasket, possibly get the head machined to make sure its not warped.
if you had to ask i'm guessing you dont know whats involved witch changing a head gasket, if you're going to a dealership be prepared to pay 4-500 bucks...possibly more depending on the ride.
Old Oct 9, 2008 | 10:53 AM
To avoid future problems, you will have to get new headbolts as well. Do not re-use the ones coming off when changing the headgasket. Some people get away with re-using them...but it is highly recommended not to.
Jon Petersen
20
Apr 12, 2019 03:29 PM
jspinelli8
Mar 26, 2018 01:31 AM
DennisWaller
Aug 6, 2008 02:33 PM
snt78
Nov 16, 2004 02:52 AM
L_K
Aug 26, 2004 06:29 PM
