CEL 9 CYP - cylinder sensor
Old Oct 9, 2008 | 09:57 AM
2ToneEM1's Avatar
Default CEL 9 CYP - cylinder sensor
Getting CEL 9 on my 99 si, car runs fine other than a stutter when giving it throttle from idle, not really missing just hesitates and sutters. And occasionaly it will sutter when pulling up a steep hill in too high of a gear.
I can usually turn the key off and back on a few times and it will run fine with no stutter.
Any help would be greatly appreciated
Thanks
Old Oct 9, 2008 | 10:08 AM
Former User's Avatar
Default Re: CEL 9 CYP - cylinder sensor (2ToneEM1)
Unless you have a bad wire between a distributor sensor and the ECU, you'll probably need to replace the distributor housing to fix the problem.
Old Oct 9, 2008 | 10:19 AM
2ToneEM1's Avatar
Default Re: CEL 9 CYP - cylinder sensor (RonJ@HT)
I put a new distributor on and it didnt help the problem, but since I was tight on money on the time I took it off and put my old one back on.
Any idea which wire it might be for that sensor?
Old Oct 9, 2008 | 10:28 AM
You have a problem with the CYP sensor circuit:
Old Oct 9, 2008 | 12:03 PM
2ToneEM1's Avatar
Thanks
AnonymousTeg
Mar 15, 2011 08:35 PM
kumar*
Aug 28, 2007 09:25 AM
LudeCris
Feb 20, 2006 06:22 PM
loud3nergy
Feb 4, 2006 09:45 AM
djtony5
Feb 20, 2003 10:09 PM
