ECU question
Trying to bump LilDevil's question. I read his other email about the swap he just did and doesn't thing it's putting out like it should. Anyways, hope someone can help him.
Elmerfudd
Elmerfudd
isnt a p2t ecu a 99-00 civic si obd2 ecu??? if it is and im sure it is, or even if it wasnt, no one can chip an obd2 ecu.. get a p28 (92-95 civic ex, si 5spd) ecu and have it chipped and get wire harness for the best performance.. there are several people that can chip it, and you if you open the ecu you will see the new chip on the board..
You cannot chip an OBD 2 ECU. You can check to see if it is chipped by opening up the ECU and there should be an extra chip around one of the corners. The chip is about one inch, by half an inch. It might have a name on the chip.
It's a P28 chip I have.. please disregard everything else I wrote.. all I wanna know is how can I tell if it's been rechipped? The guy said he reprogrammed my P28 and I wanna know if there is anyway that I can confirm that for myself.
NO no no! You do not have a p28 chip. The p28 is the stock single cam vtec ECU out of a 92-95 civic ex coupe, or 92-95 hatch si. A reprogrammed p28 is a p28 ECU with a chip in it. Scroll back up and I already told you how to check it. All you need is a screw driver and one eye.
cheers.
