b16a sir II into 91 crx si electric vss or cable
Old Oct 8, 2008 | 07:21 PM
catfishracer4748's Avatar
Default b16a sir II into 91 crx si electric vss or cable
I have a 91 crx si I'm putting a b16a sir II engine into. It has a p30 ecu. I had the harness made by rywire. The problem that im running into is the lsd trans with this swap uses an electronic vss sensor while my crx uses a speedo cable. The harness rywire made does not appear to have the connector for the vss. So do I need to get an sir cluster and also wire up the vss so my vtec and everything works correctly? Does anyone manufacture an aftermarket elec. vss/speedo cable combo? I know I can slide my cable in the elec. vss if I take it apart but Im not sure if this is the correct fix? Any help would be greatly appreciated. Thanks.
Old Oct 8, 2008 | 07:35 PM
ttm_sales's Avatar
You can put the cable VSS in that tranny, and that would be the correct way to do it if the harness does not have the Electronic VSS plug.
Old Oct 8, 2008 | 07:49 PM
Default Re: (ttm_sales)
Yea I know I can do that and make my speedo work but I'm more concerned with making the engine work correctly. I believe this engine needs vss signal for a few of the engine functions. Anyone else have any ideas?
Old Oct 8, 2008 | 08:14 PM
D16SiHatch's Avatar
Default Re: (catfishracer4748)
all you need to do is get rid of the electronic vss and use a cable style vss, then plug your stock cable into that. or if you think you can make the electric one work, well by all means go that route. the cluster converts that input from the cable into an electric output that is sent back to the ecu via a red/yellow wire i believe it was. you don't have to wire in anything extra. its already a part of the stock harness, and therefore it remains after the conversion harness is added.
Old Oct 8, 2008 | 08:42 PM
ttm_sales's Avatar
Just use the cable, it will work just fine, the engine does not need an electronic VSS
Old Oct 8, 2008 | 08:56 PM
Shermanef9's Avatar
im with these guys..
i've done the same swap, but with an EF hatch, i just used cable VSS
Old Oct 8, 2008 | 08:57 PM
HOODLOVER's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shermanef9 &raquo;</TD></TR><TR><TD CLASS="quote">im with these guys..
i've done the same swap, but with an EF hatch, i just used cable VSS</TD></TR></TABLE>
x2
Old Oct 9, 2008 | 04:17 AM
CRX Toad's Avatar
Default Re: (HOODLOVER)
Please keep this all together https://honda-tech.com/zerothread/2403998
EF-8SiR
Jan 27, 2009 08:34 PM
JohnCRX
Jul 29, 2004 09:00 AM
JohnCRX
Jul 28, 2004 02:07 AM
HT Chaplain
Apr 16, 2003 11:05 AM
b16powwer
Jul 20, 2002 06:15 AM
