92-95 Civic Taillight Swap I need to know what wires are what
Old Oct 8, 2008 | 05:47 PM
JDM-JAMES's Avatar
Default 92-95 Civic Taillight Swap I need to know what wires are what
hey well im having a problem with the tail light harness i need to know what order the wires go here are pics of how mine are setup its not correct if you guys could take pics of the way your wires are that would be great
the problem is the inner tail light wires the reverse light turns on instead of the bottom part
Old Oct 8, 2008 | 07:43 PM
solturbob16sol's Avatar
* B A N N E D *
Default Re: 92-95 Civic Taillight Swap I need to know what wires are what (JDM-JAMES)
r u dumb the wire colors r the same just match them
Old Oct 8, 2008 | 07:48 PM
Davus's Avatar
Default Re: 92-95 Civic Taillight Swap I need to know what wires are what (solturbob16sol)
Ahh, not necessarily. Tail light lenses/assembly and the associated wiring harness for the bulbs are entirely separate entities. Plus, OP could have aftermarket sockets regardless.
I'll look up the info, OP.
E: bah, no result thus far. have a multimeter, op?
Old Oct 8, 2008 | 08:04 PM
Jonathan_ED3's Avatar
Match up the colors - assuming you have Honda tails/sockets. Not sure why aftermarket would be any different though....
Red/black - parking
green/white - brake lights
green/black - reverse lights
....for all Hondas since the beginning of time
EDIT: Are you sure the problem is your Harness?
I see lots of people (all the time, I work in auto parts) have their reverse light bulbs installed where the brake lights, and/or turn signal lights should go. And then when you step on the brakes (or whatever function) the wrong section of the lamp assembly lights up.
erikwithak
11
Aug 8, 2009 11:09 AM
DCSportEJ1Civic
May 12, 2007 09:06 AM
whiteej1
Sep 15, 2006 05:10 PM
CivicHB93JDM
Nov 26, 2005 07:40 AM
lowlude92
Jan 15, 2003 05:09 AM
