96-00 window out of alignment problem.
Old Oct 8, 2008 | 03:56 PM
dingobat's Avatar
Default 96-00 window out of alignment problem.
I have a 96 4d ex;
my problem s my driver's window. when the window goes up, the window gets pushed out of the rubber slit that holds the side of the window. So before i want to close the window, i have to use my fingers and put some pressure on it to stay in the rubber slit.
i don't know what the problem. It seems like the window seems loose as i can kinda twitch it from sideway to sideway a little just enough for the window to get out of the rubber slit.
anyone have any idea?
Old Oct 8, 2008 | 04:09 PM
FRKWOO's Avatar
Default Re: 96-00 window out of alignment problem. (dingobat)
i have the same problem
Old Oct 9, 2008 | 04:54 AM
tercel95's Avatar
Welcome to owning a honda, not much you can do besides take the door panel off, lubricate the tracks with spray silicone, and wait for it to happen again...
Old Oct 9, 2008 | 06:08 AM
south_sac_red_ek's Avatar
its your window brackets... i had that happen to mines and took it all apart and aligned it and put it all back together and its back to normal now...
Old Oct 9, 2008 | 08:35 AM
dingobat's Avatar
hey south_sac_red_ek,
so how do i fix this? I've taken my inside dorr panel out, but i can't get around the inside where the window lies. Are there step by step instruction on how to fix this problem? or fix the window brakets?
Old Oct 9, 2008 | 09:56 AM
tercel95's Avatar
https://honda-tech.com/zerothread?id=2061336
Its pretty easy to do, after you get the window back in the track make sure you lubricate the tracks with spray silicone.
4Dinsaneb16
Mar 20, 2007 01:30 PM
WhiteOnRice
Jun 23, 2006 04:15 PM
KEVlN
11
Nov 11, 2005 08:36 PM
rasinhell
May 20, 2005 12:38 AM
