Smog
Old Oct 8, 2008 | 02:20 PM
rockcity's Avatar
Default Smog
I just failed the smog test in Portland. I have 90 crx. Does anyone have any suggestions as to what I can do to correct this? Thanks.
Old Oct 8, 2008 | 02:23 PM
sgallagher's Avatar
Default Re: Smog (rockcity)
need your #'s. HC, CO, O2 etc..
Old Oct 8, 2008 | 04:22 PM
rockcity's Avatar
Default Re: Smog (sgallagher)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgallagher &raquo;</TD></TR><TR><TD CLASS="quote">need your #'s. HC, CO, O2 etc..</TD></TR></TABLE>
Sorry. The only thing I failed was the HC. I was too high by about 225 or so. I don't have the numbers in front of me.
Old Oct 8, 2008 | 06:08 PM
dacrxguy's Avatar
if it is hc then that means u are getting unburned fuel down your pipe i would first invest in a new cap, rotor, wires, spark plugs and air filter for a cheap way out the second thing i would look at is the cat and how old it is
Old Oct 8, 2008 | 06:40 PM
rockcity's Avatar
Default Re: Smog (dacrxguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dacrxguy &raquo;</TD></TR><TR><TD CLASS="quote">if it is hc then that means u are getting unburned fuel down your pipe i would first invest in a new cap, rotor, wires, spark plugs and air filter for a cheap way out the second thing i would look at is the cat and how old it is</TD></TR></TABLE>
Well, the plugs, wires, and air filter are all brand new. I imagine that the cat is original however. Also, should I just purchase a whole distributor or can I just get the cap and rotor? Thanks
Old Oct 8, 2008 | 06:53 PM
dacrxguy's Avatar
just the cap and rotor no need to buy a new dizzy like they always say if it aint broke dont fix it and if it broke while your fixing it it needed to be replaced
Old Oct 8, 2008 | 07:56 PM
rockcity's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dacrxguy &raquo;</TD></TR><TR><TD CLASS="quote">just the cap and rotor no need to buy a new dizzy like they always say if it aint broke dont fix it and if it broke while your fixing it it needed to be replaced </TD></TR></TABLE>
Hey man, thanks for all of the help. I have two more questions. First, how do I tell if the cat is bad, and second, is there any way to tell if the rotor and cap are actually bad or should I just go ahead and replace them?
Old Oct 8, 2008 | 08:05 PM
tico's Avatar
a good way is ur exhaust smell. if it smells bad then u should replace it. check and or replace ur O2 sensor with and OEM one.
Hondalosser
Oct 31, 2015 08:48 PM
fiction1990
12
Nov 3, 2014 11:12 AM
turtleef
Jun 26, 2012 09:15 PM
Uncle Willie
Nov 21, 2007 02:17 PM
rodvang
20
Oct 2, 2007 10:58 AM
