Radiator Fan Issues...!
Will a radiator fan turn on if the cap isn't secured properly..?? I got home today and my hatch smelled a lil like antifreeze, so i popped the hood and seen my overflow literally overflowing & making that boiling water sound.. Well i go inside to let the car cool down, come out about 20 minutes later and my overflow is completely bone dry..???? So i took off the cap and it came off in 2 pieces, it was the upper portion of the cap to come off first, than the part that seals the hole and the spring were still in where the radiator cap goes..?? So i start the car and start adding fluid until its full, but bubbles kept on coming up for about 10-15 minutes... Meanwhile, this whole time i keep adding fluid my radiator fan's not coming on at all... I turned on the A/C for 5 minutes, nothing, turned on the heat for about 5-10 minutes, nothing... So i took some speaker wire and jumped the plug on top of the radiator and the fan turned on...?? Anybody know whats goin on here..??
ps - my car wasn't overheating either, stayed a spec under halfway on the temp gauge... also, it was about 92 degrees out today in sunny southwest florida so it doesn't take much usually for my car to get to regular operating temperature "meaning that my fan should have kicked on asap i'd assume"....
One of my friends who helped me with my last swap, setup the radiator fan to come on with the ignition... I think he did something around the thermostat area, or in that little fuse box under the hood next to the battery, but i was to busy putting on my turbo and exhaust to pay attention to what he did... Anyone know of that solution as well, considering i kno my fan is good at least, and all the fuses are working properly...
i dont know about the radiator problem but the fan isnt kicking on because the engine coolant temp switch is bad.u can jump the plug but its just ghetto.
The coolant temperature switch is located on the thermostat housing. Disconnect the connector from the sensor and insert each end of a short piece of wire into the two terminals of the 2P connector. If only the switch was bad, the radiator fan should now run continuously when the ignition key is turned ON.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RonJ@HT »</TD></TR><TR><TD CLASS="quote">The coolant temperature switch is located on the thermostat housing. Disconnect the connector from the sensor and insert each end of a short piece of wire into the two terminals of the 2P connector. If only the switch was bad, the radiator fan should now run continuously when the ignition key is turned ON.</TD></TR></TABLE>
dude just get the ect switch man its probably like 20bucs.i had the same problem on my d motor i jumped the plug like u and my battery went dead.
i talked to my mechanic today "from before i did all my own work" an he said bypassing that thermostat switch only gives the fan power when the ignition is on so my battery shouldn't go dead unless the key is left in the ACC position, and I should be alright until I can replace it.... He's been my neighbor for 18 years and always hooked me up so I think i'll be good til I can get around to gettin a new one... This motor's not staying in for long so i'll just ride it out i'm sure, thanks for ur help guys...
milkwasabadidea
Jan 8, 2011 10:22 AM
TC21
May 9, 2006 11:19 AM
Lei Siew Long
Sep 21, 2002 10:43 AM
