b16a2 sputtering shutting off
Old Oct 8, 2008 | 12:06 PM
04silvep3's Avatar
Default b16a2 sputtering shutting off
ok well iv had the car for about 5 months with the swap NEVER had this problem before if i eas off from a dead stop after like 3000 rpm its sputters until around 5000 then shutts off but it catches itself at 1500 rpm and does the same in second but only at certain times does anyone have any idea whats going on
Old Oct 8, 2008 | 02:01 PM
04silvep3's Avatar
anyone?
Old Oct 8, 2008 | 05:59 PM
z6hatchboy's Avatar
Possible igniter coil, try a new dizzy
Old Oct 8, 2008 | 06:00 PM
z6hatchboy's Avatar
check for codes too
Old Oct 8, 2008 | 07:24 PM
ttm_sales's Avatar
You should check for fuel issues, possibly bad pump or fuel filter issue.
Old Oct 8, 2008 | 08:46 PM
04silvep3's Avatar
ok well no codes as as far as the rest ill try fuel pump is only 4 months old an its only wen im driving in first or second
Old Oct 8, 2008 | 08:58 PM
Ctown2Ctown's Avatar
Default Re: (04silvep3)
sounds kinda like a map sensor problem or an ignition problem to me <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6hatchboy &raquo;</TD></TR><TR><TD CLASS="quote">Possible igniter coil, try a new dizzy</TD></TR></TABLE> this man speaks the truth. break out the old voltmeter, and get the factory voltage table for the map sensor from honda, and check it the old fashioned way.
Old Oct 9, 2008 | 07:38 AM
04silvep3's Avatar
well i checked the spark with a spark tester an its sparking just fine i can try another map sensor but wuddnt any of this throw a code?
Old Oct 12, 2008 | 06:47 PM
04silvep3's Avatar
ok well would this have anything to do with my IACV i just checked my codes again today and now i have a code 14 for IACV any idea?
Old Oct 12, 2008 | 06:55 PM
DCFerris's Avatar
yeah that would make the rpms to jump around. what you could do is take off your iacv and clean it and check the o rings to make sure there still good and see if it helps any just go down to an auto part store and buy carb cleaner and spray it down
Old Oct 12, 2008 | 07:05 PM
04silvep3's Avatar
but it wud make the car shut off an come back like that?
Old Oct 13, 2008 | 05:36 AM
04silvep3's Avatar
Default Re: b16a2 sputtering shutting off (04silvep3)
Old Oct 14, 2008 | 03:01 AM
DCFerris's Avatar
i dont think it would make it shut off like that but its not gonna hurt any if you do check out you IACV but thats just thinking
Old Oct 15, 2008 | 06:43 AM
04silvep3's Avatar
replaced the iacv no difference still doin it
Old Oct 16, 2008 | 08:52 PM
04silvep3's Avatar
update got some new codes now
p1456 manufacturer control auxiliary emissions controls
p0170 fuel trim malfunction
Old Oct 16, 2008 | 08:53 PM
04silvep3's Avatar
anyone know what this is its driving me nuts
Old Oct 16, 2008 | 09:28 PM
Honda-Pilot's Avatar
Make sure the TPS and MAP sensors arn't broken from shipping the motor.
Once it throws a CEL, check for the codes before you shut the motor off.
The P1456 is EVAP leak, usually the gas cap is lose.
Old Oct 16, 2008 | 09:43 PM
04silvep3's Avatar
gas cap is fine the tps is good i gotta check the map an i cant figure out that fuel trim malfuntion
Old Oct 16, 2008 | 09:49 PM
The fuel trim problem is probably a result of your missfire, it's not the actual problem.
Until you get a code, your on a wild goose chaise. You should be looking for a code reguarding CKP, MAP, TPS, CMP, or TDC.
Old Oct 17, 2008 | 04:05 PM
04silvep3's Avatar
well my car dosnt misfire i guess il startby changing the map cuz everything else is new
Old Oct 17, 2008 | 04:24 PM
That's an expensive guess. I'd test it first. Hook your volt meter up to the signal wire and slowly create vacuum with your vacuum guage. The voltage should increase slowly as you add vacuum. If there is a voltage spike somewhere, then the sensor is bad. You should be doing this with the key on engine off and the connector connected. This test is best done with a scope, where you can actually watch to voltage increase. Good luck!
Old Oct 19, 2008 | 04:54 PM
04silvep3's Avatar
well i swapped the ecu and now the car dosnt shut off or sputter so im gunna need a new ecu
crave13k
Sep 2, 2011 11:33 PM
1SlowSiHB
Dec 21, 2009 04:47 AM
ScandalousCivic
May 10, 2005 06:20 PM
The G2 Racer
Nov 6, 2002 03:29 AM
