d16z6 redlines at 3500 when warmed up?????
my d16z6 is redlining at 3500 when it gets warmed up
it revs fine until then and then once it gets warmed up it just keeps redlining at 3500
I need help..
I need help..
Re: d16z6 redlines at 3500 when warmed up????? (benji1246)
it got no codes but my #2 cylinder injector wire wont work but when I hook the #1 cylinder injector wire up to it it does and i put the #2 cylinder injector wire on #1 injector and it works there???????
Could this be causing the limp mode???
Location: ....................................................................................................
well either that or someone has pulled your CEL bulb and you don't think your getting any codes and that could be the reason why its in limp mode because of you messing around with the wires, how do you know it works when you play with the injector wires? did you unplug them before and put it back in the connector?
I thought limp mode was 4,000 RPM. It could be different for other ECUs but here's my car in limp mode
http://www.youtube.com/watch?v=SCDrlCfFqqI&fmt=18
Does yours act like this?
project civic
02-02-2006 04:34 AM
MAFDARK
01-19-2005 10:43 AM
