Transmission & Drivetrain Gearboxes, Differentials, Clutches
Tore my B16 tranny apart and found this..... :(
Old Oct 8, 2008 | 11:56 AM
SneezinCD5's Avatar
Default Tore my B16 tranny apart and found this..... :(
Got the thrans. with a trade and found out the main shaft bearing was bad so I tore it down to replace it today and got another suprise. Here are some pics. Not the best but you can see what I am working with. Is this thing worth fixing? What will happen if I just install it like this? All of the other parts/gears look good. Its the differential gears.
Modified by SneezinCD5 at 4:32 PM 10/8/2008
Old Oct 8, 2008 | 12:53 PM
Mista Bone's Avatar
D Tranny Guru
big bang theory about to be proven!
Old Oct 8, 2008 | 01:32 PM
Aquafina's Avatar
Install it like that and you will need a new transmission.
Replace the diff.
Old Oct 8, 2008 | 03:47 PM
SneezinCD5's Avatar
Default Re: (Aquafina)
Where can I find one? Looked at Majestic but couldn't find it.
Old Oct 8, 2008 | 05:39 PM
Aquafina's Avatar
Will be under MT, usually listed as MT Differential.
Old Oct 8, 2008 | 08:28 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: (SneezinCD5)
MT Differential
1999 Civic Si
http://www.hondaautomotivepart...HC%29
I'd think about a MFactory unit at that price, I've given up on OBX.
Old Oct 8, 2008 | 09:03 PM
SneezinCD5's Avatar
Default Re: (Mista Bone)
Im just trying to fix it and sell it. I won't get my money back if I go with an LSD or a new OEM part. Might try to find a used one just to get it out of here.
Old Oct 10, 2008 | 03:27 PM
LA_HONDAS's Avatar
how much you want for it as is
and is it hydro?
Old Oct 10, 2008 | 05:04 PM
siregcivic's Avatar
Default Re: (LA_HONDAS)
just buy an ebay lsd from obx make sure you strip the obx and make sure its assembled correctly and your ready to rock
Old Oct 10, 2008 | 05:10 PM
SneezinCD5's Avatar
Yes, its hydro. I was asking 500 since I replaced all of the seals and the mainshaft bearing but don't know what its worth now.
Old Oct 10, 2008 | 05:22 PM
LA_HONDAS's Avatar
you might as well put a new diff in it and use it
you could use a ls diff in it but you have to switch the ring gear on it
Old Oct 10, 2008 | 09:02 PM
civickiller's Avatar
lsd, best thing i got for my tranny
Old Oct 10, 2008 | 09:08 PM
SneezinCD5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LA_HONDAS &raquo;</TD></TR><TR><TD CLASS="quote">you might as well put a new diff in it and use it
you could use a ls diff in it but you have to switch the ring gear on it</TD></TR></TABLE>
I have no use for it. I have a D16Y7 in my hatch. Not gonna mess with B seires anymore, I will swap a K in when its time.
Old Oct 11, 2008 | 05:09 PM
shaggyeg6si's Avatar
clean the affected areas and weld the spider gears closed. you now have a no slip differential.
Old Oct 12, 2008 | 06:11 AM
CubanoRockr's Avatar
Default Re: Tore my B16 tranny apart and found this..... :( (SneezinCD5)
just try to find one on here, somebody has to be selling one
Old Oct 12, 2008 | 01:12 PM
SneezinCD5's Avatar
Default Re: Tore my B16 tranny apart and found this..... :( (CubanoRockr)
Found one for 80 shipped....Sound resonable? Don't know if it matters but this one is coming from a GSR.
Old Oct 12, 2008 | 05:19 PM
LA_HONDAS's Avatar
it wont work unless you have the ring gear for it
the b16/ls ring gear wont fit on a gsr diff..
Old Oct 12, 2008 | 05:27 PM
SneezinCD5's Avatar
Default Re: Tore my B16 tranny apart and found this..... :( (LA_HONDAS)
Ok, guess thats no good. I am in need of a B16 one.
Old Oct 12, 2008 | 06:37 PM
siregcivic's Avatar
thats strange, i just replaced my buddies broken gsr diff with a ls diff and used the gsr ring gear and it has no problems whatsoever hmmm..
broken gsr diff has a snap ring stuck in it so the axle would pop out all the time finally he said [freak]it replace my diff
Old Oct 12, 2008 | 06:48 PM
SneezinCD5's Avatar
Default Re: Tore my B16 tranny apart and found this..... :( (siregcivic)
I just want the whole diff. not trying to take anything alse apart. I might just sell it for a hundred or 2.
Old Oct 13, 2008 | 12:53 AM
Mista Bone's Avatar
D Tranny Guru
I call bullshit here
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siregcivic &raquo;</TD></TR><TR><TD CLASS="quote">thats strange, i just replaced my buddies broken gsr diff with a ls diff and used the gsr ring gear and it has no problems whatsoever hmmm..
Old Oct 13, 2008 | 09:13 AM
siregcivic's Avatar
Default Re: Tore my B16 tranny apart and found this..... :( (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">I call bullshit here
im dead serious
Old Oct 13, 2008 | 09:40 AM
MFactory's Avatar
Means you must have had a GSR diff then and didn't know it
Old Oct 13, 2008 | 10:38 AM
SneezinCD5's Avatar
Default Re: (MFactory)
Ok, does anyone have a B16 diif. so I can put this back together and get rid of it? Im tired of seeing it.
Old Oct 13, 2008 | 01:02 PM
siregcivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MFactory &raquo;</TD></TR><TR><TD CLASS="quote">Means you must have had a GSR diff then and didn't know it </TD></TR></TABLE>
actually im sorry, it was a b16 diff, i kept the ls diff in my tranny...
it was a 99-00 si tranny, i took the mainshaft and kept the ls countershaft so i could use the b16 gears with ls final drive and kept it together with the diff, we put the b16 tranny into the gsr case....
that or theres something else going on because i went to put the b16 diff in with ring gear and it wouldnt fit, so i put on the gsr ring gear to the b16 diff and everything lined up and worked fine
