Civic radiator in a GSR
Old Oct 8, 2008 | 09:41 AM
bseries637's Avatar
Default Civic radiator in a GSR
Anything wrong with running a civic radiator in a GSR? Should I switch it out???
Old Oct 8, 2008 | 09:43 AM
AWD Terror's Avatar
Default Re: Civic radiator in a GSR (bseries637)
No. A lot of people run half rads
Old Oct 8, 2008 | 09:58 AM
SuzukaBlueAP2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AWD Terror &raquo;</TD></TR><TR><TD CLASS="quote">No. A lot of people run half rads</TD></TR></TABLE>
x2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bseries637 &raquo;</TD></TR><TR><TD CLASS="quote">Anything wrong with running a civic radiator in a GSR? Should I switch it out???</TD></TR></TABLE>
what makes you want to do it? I don't think I would do it just for something to do, but, it will work fine. Most people do it need clearance for a turbo.
Old Oct 8, 2008 | 10:03 AM
ekred9's Avatar
yeah it'll work but you have to get one of the extra mounts from your stock full sized radiator and use it as a bottom mount for the civic rad
Old Oct 8, 2008 | 11:48 AM
steveharrmr23's Avatar
Default Re: Civic radiator in a GSR (ekred9)
i did it cause it was cheaper then a full size one i mounted mine with out haveing to drill any new wholes or welding anything
Old Oct 8, 2008 | 11:51 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I wouldn't do it if you still have A/C. Civics have a half-width radiator and a half-width A/C condenser. Integras have both components full width, with the condenser sitting in front of the radiator. Both fans draw air through both components. If you switch to a half radiator, then your fan will only draw air through half of the condenser.
Old Oct 8, 2008 | 12:26 PM
vietnamezerice's Avatar
Default Re: (PatrickGSR94)
i guess it'll work if you find a way to keep a fan on the condenser too
Old Oct 8, 2008 | 09:47 PM
Default Re: (vietnamezerice)
could always get a small 8 inch universal fan for the condensor
Old Oct 8, 2008 | 09:54 PM
Default Re: (steveharrmr23)
just make sure it has enough CFM's
str8JDMteggy
Feb 14, 2007 10:07 AM
JKov240
Oct 5, 2006 02:34 PM
zeroz
Sep 11, 2005 03:40 PM
Hatch It
Jul 16, 2005 07:23 AM
TRM04
Jan 6, 2003 11:29 AM
