zc sohc vtec turbo problems
okay i just finished installing my turbokit in my car
no sure what turbo is it but will check later today
i drove the car and the boost gauge shows 8-10 psi but after a couple minutes the car starts to act like is clogged
then i turn it off for a couple of minutes and it works fine
then i drive again and here it goes again
i have everything stock from fuel pump to injectors to spark plug and spark plug wires
except
stage 2 exedy clutch and nopi ultra lightweight flywheel
i have a drag style manifold (ac friendly ftmfw)
intercooler piping
intercooler
xs something wastegate
blowoff valve
autometer procomp ultralight boost/vac
glowshift oil pressure
one oil/water temp
what else should i do i'm on a budget since i have to send my dog to brazil anyways let me know thank you all
apexi n1 catback with a ebay racing cat
except
intercooler piping
intercooler
blowoff valve
one oil/water temp
your going to need bigger injectors and a tune...fuel pump isnt really a must have unless you plan on making alot more power than stock and im sayin 300whp...i would recommend some dsm450cc injectors with resistor box and some ngk bkr7e spark plugs
^ Word. 450's would be perfect for you, some better exhaust, a adjustable fuel pressure regulator and a walbro 195 wouldnt hurt either. TUNE TUNE TUNE! Unless you want to blow your motor, you need to get it tuned. http://www.turbod16.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junior_tm »</TD></TR><TR><TD CLASS="quote">now what should i chip my ecu wit?
neptune?
crome pro?
what you guys suggest</TD></TR></TABLE>
Should of done your research before half assing a turbo setup
You can go get s300 and pay for a shop to tune your car, which will cost you a pretty penny.
Or you can just find someone who can street tune on the side for you and just get crome.
GL.
neptune?
crome pro?
GL.
skateboard_ej8
Appearance Build Threads
206
Feb 13, 2012 02:45 PM
