HELP!! CRANKS BUT WONT START,NO FUEL AND SPARK !!
Old Oct 7, 2008 | 10:11 PM
trav143's Avatar
Default HELP!! CRANKS BUT WONT START,NO FUEL AND SPARK !!
yanked the motor and tranz put a new trans in will not sart
Old Oct 7, 2008 | 10:33 PM
trav143's Avatar
Default Re: HELP!! CRANKS BUT WONT START,NO FUEL AND SPARK !! (trav143)
plese help
trav143's Avatar
Old Oct 8, 2008 | 09:18 AM
trav143's Avatar
hellp
Old Oct 8, 2008 | 09:43 AM
EJ1_Ex's Avatar
check your fuses! check your dizzy..do you hear the fuel pump prime? main relay?
Old Oct 8, 2008 | 10:02 AM
SinsEvil666's Avatar
Grab a tester....start testing the Fuel pump wires and the dizzy wires...start from either the fuel pump/dizzy or from ECU...wherever spark/current stops....that might be the problem.
Old Oct 8, 2008 | 10:07 AM
trav143's Avatar
Default Re: (SinsEvil666)
dot hear the fuel pump prime thats the frist thing that i tride i put gas in the in tack thhin look for spark no spark it sucks
Old Oct 8, 2008 | 10:10 AM
trav143's Avatar
Default Re: (trav143)
it ran friday be for i poled it
Old Oct 8, 2008 | 10:36 AM
instructor74's Avatar
my god please proof read and use the spell check. It hurts trying to read what you posted and I have no clear idea of what you have tested. First you say that you have spark then no fuel
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trav143 &raquo;</TD></TR><TR><TD CLASS="quote">yanked the motor and tranz put a new trans in will not sart</TD></TR></TABLE>
then you post this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trav143 &raquo;</TD></TR><TR><TD CLASS="quote">dot hear the fuel pump prime thats the frist thing that i tride i put gas in the in tack thhin look for spark no spark it sucks</TD></TR></TABLE>
So are we to guess buy this that you have no fuel and no spark or is it spark and no fuel or fuel and no spark.
So first check to see if the fuel pump primes when you turn the key on, If you just pulled something??? make sure all the grounds are hooked up and connectors are plugged in.
Old Oct 8, 2008 | 10:45 AM
trav143's Avatar
Default Re: (instructor74)
Old Oct 8, 2008 | 10:46 AM
trav143's Avatar
how much is main relay and where is it on a 2000 civic
mines maks funny sounds like give ing off mose code
Old Oct 8, 2008 | 10:58 AM
mistik_DC4's Avatar
Your timing belt might have snapped. Happened to my friends car. Open your oil cap and have someone crank your car. Look to see if your cams crank.
zcmotor
30
Mar 17, 2008 05:53 PM
slowassciv33
10
Jul 1, 2007 04:04 PM
blueR87
Aug 5, 2005 01:10 AM
temp
15
Jul 6, 2004 08:07 PM
advanracing62
Mar 15, 2004 05:57 AM
