Hesitation at low RPMs
Old Oct 7, 2008 | 05:05 PM
solstice's Avatar
Default Hesitation at low RPMs
Today, on the way back home from work, after getting off the highway I experienced some hesitation at low RPMs in the lower gears. 1st, 2nd and sometimes 3rd consistently at about 1000 rpm the car will hesitate and shake real hard. I work ~70 miles from home, take the highway 60miles and get off and go 10miles in the city. No problems on highway, just after getting into the city. I shut off the car at home for an hour and restarted and took it around, it still did it, but it was much less severe.
Car is 95 del sol d15b7, all stock, dist/plugs/wires in last 3 months
145k w/ original clutch and timing belt
Any advice? Thanks
Old Oct 7, 2008 | 05:33 PM
SOHCmyNUTZ's Avatar
Default Re: Hesitation at low RPMs (solstice)
it could be the timing. if it lags at low gears but runs okay in higher gears or higher rpms you should check your timing belt. it may have jumped or it may need to be replaced already.
Old Oct 7, 2008 | 06:46 PM
EH3USDM's Avatar
Some of the things that I would check would be o2 sensor, fuel filter, spark plugs, and cap and rotor.
Old Oct 31, 2008 | 03:29 PM
civbomb's Avatar
mine does the same thing, and i have replaced everything but the o2 sensor. have you figured out the problem?
That89Si
Feb 20, 2018 05:09 PM
ozm0tik
Aug 27, 2010 08:58 PM
djtony5
Dec 8, 2005 09:51 AM
Inspector Gadget
Sep 2, 2004 02:26 PM
SIK IN DA HED
Nov 22, 2002 03:43 PM
