turbo crank shaft
Old Oct 7, 2008 | 01:52 PM
adam00's Avatar
Default turbo crank shaft
in the future i want to build a poor mans type r turbo (b18c1 bottom end and b16 head) and i was wondering what crank would be better to use a ls crank or a gsr crank both made by eagle and they both way 27pounds and im looking to fully build this motor to make 700whp and i would like to get as much torque as a can but i dont know if the eagle ls crank could handle the high revs and be reliable
Old Oct 7, 2008 | 02:06 PM
Schister66's Avatar
Man U FTW
I would go with an OEM LS Crank. I've seen the infamous pics of Eagle crank failure...
Old Oct 7, 2008 | 02:23 PM
adam00's Avatar
Default Re: (rota92)
how about the je ls cranks
Old Oct 7, 2008 | 02:50 PM
champLSinteg's Avatar
Default Re: (adam00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adam00 &raquo;</TD></TR><TR><TD CLASS="quote">how about the je ls cranks</TD></TR></TABLE>
Why dont you try it! I will be #3 to tell you to just go with OEM crank...(LS or GSR)
Old Oct 7, 2008 | 04:24 PM
ITR-EKcoupe's Avatar
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote"> I've seen the infamous pics of Eagle crank failure...</TD></TR></TABLE>
yup
Old Oct 7, 2008 | 04:28 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (ITR-EKcoupe)
710 on a stock gsr here.
#4 for stock.
he hee.....carnage:
Old Oct 7, 2008 | 04:32 PM
adam00's Avatar
Default Re: (boostedcivicsir)
what about getting a stock crank micro polished and balenced and where can i get that done
that pic of the broken crank and block what crank was that
Old Oct 7, 2008 | 04:34 PM
Mr. Badwrench
it was an eagle, dont know if it was ls or gsr, but at that point it dont much matter.
Old Oct 7, 2008 | 04:44 PM
adam00's Avatar
what crank would you guys use is a build like this ls or gsr
Old Oct 7, 2008 | 04:52 PM
[QUOTE=boostedcivicsir]
he hee.....carnage:
OMFG!
thats the worst ive ever seen
Old Oct 7, 2008 | 04:55 PM
Mr. Badwrench
if i wouldnt have gotten charged a 25% restock on my rods to switch to ls, i would have used an ls crank. because i already had gsr rods.
if i had it to do all over again, i would do ls.
Old Oct 7, 2008 | 05:29 PM
adam00's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rota92 &raquo;</TD></TR><TR><TD CLASS="quote">
It's not going to matter much, the small extra bit of stroke is nice with the LS but it's so minimal I can't see a back to back setup at moderate power seeing too much of a change.
The LS' do have wider journals though.</TD></TR></TABLE>
is there a problem with the ls crank having wider journals will it fit in a gsr block with out problems/mods?
CeeJayy
Apr 1, 2007 11:52 AM
ProjectBoosted
Oct 23, 2006 10:02 AM
kingteghelm
Jun 28, 2005 10:59 PM
BryanEk
Feb 27, 2005 06:14 PM
MARC P
May 27, 2003 07:07 AM
