Tokico Illumina shock and spring kit?
Old Oct 6, 2008 | 02:39 PM
BoltonGSR's Avatar
Default Tokico Illumina shock and spring kit?
I was interested in the illuminas and found this kit online from a ht sponsor..
Its the illuminas with tokico springs tossed in to make a kit..
http://www.statracing.com/buy/...t.asp
Anyone ever try this kit? How is it?
Old Oct 6, 2008 | 04:35 PM
HONDRETTI's Avatar
Default Re: Tokico Illumina shock and spring kit? (BoltonGSR)
my friend had this set up on his civic. he always enjoyed the adjustability of the illiuminas, but he always found himself switching from softer to stiffer for highway use, and vice versa for around town. i would have no opposition, i thought they rode pretty well.
Old Oct 6, 2008 | 05:17 PM
BoltonGSR's Avatar
Default Re: Tokico Illumina shock and spring kit? (HONDRETTI)
Well, i know the illuminas are good. Im really wandering who has tried the tokico springs in this kit and if they are worth it?
Old Oct 6, 2008 | 07:35 PM
ddtfrom626's Avatar
I also looked into buying that setup. I found that its a step above tokico blues and a little better than KYB AGX. I think its better to get a used set of better shocks and springs. I found koni yellows and eibach sportlines for 400. check craigslist or hondamarketplace for used parts.
Old Oct 6, 2008 | 07:49 PM
racebum's Avatar
Default Re: Tokico Illumina shock and spring kit? (ddtfrom626)
shocks are fine, the springs are trash though. stock rates with a lower height, that's it. i would just buy the shocks and get a real lowering spring like the tein h or s tech or the h&r sports. the rates are much better on any of those 3.
Old Oct 7, 2008 | 03:20 AM
BoltonGSR's Avatar
Default Re: Tokico Illumina shock and spring kit? (idrivesideways)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idrivesideways &raquo;</TD></TR><TR><TD CLASS="quote">shocks are fine, the springs are trash though. stock rates with a lower height, that's it. i would just buy the shocks and get a real lowering spring like the tein h or s tech or the h&r sports. the rates are much better on any of those 3. </TD></TR></TABLE>Hmmm, thanks. I was actually thinking eibach prokit
Old Oct 7, 2008 | 11:15 AM
racebum's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoltonGSR &raquo;</TD></TR><TR><TD CLASS="quote">Hmmm, thanks. I was actually thinking eibach prokit</TD></TR></TABLE>
or those, just check the rates at team-integra.net and make sure it's around the lbs you want. they have an article of most every lowering spring rate.
Old Oct 7, 2008 | 12:56 PM
96teggynonVtec's Avatar
not sure if they are the same but i have the Tokico RAK Coilovers and love them...
http://www.horsepowerfreaks.co.../9803
Old Oct 7, 2008 | 01:02 PM
SleeperGSR's Avatar
Default Re: (96teggynonVtec)
That's interesting to know. I have the same set-up and i have been complaing about my spring rates trying to figure out what they were so i could go stiffer. Now that i know this i know why i was complaining. thanks for the info.
Old Oct 7, 2008 | 05:11 PM
skynyrd006's Avatar
Default Re: (SleeperGSR)
My father has this set up on his dd crx. The springs are soft and dont lower the car that much, but its an excellent choice for daily driving imo.
Old Oct 7, 2008 | 07:56 PM
SleeperGSR's Avatar
Default Re: (skynyrd006)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skynyrd006 &raquo;</TD></TR><TR><TD CLASS="quote"> its an excellent choice for daily driving imo.</TD></TR></TABLE> X2
Old Oct 7, 2008 | 09:19 PM
b18integraboy's Avatar
i had the same set up on my DA like over a year ago. it only lowered the car about 1 inch but i liked the ride. i later got GC's and sold the springs for 60 bucks.
HERES THE STOCK HIGHT
THE KIT
ON THE CAR
AND THE NEW SETUP
Old Oct 7, 2008 | 11:06 PM
FuNkDrSpOt's Avatar
Default Re: (b18integraboy)
I have the Eibach pro's and the Tokico. Nice setup. Provides extra cornering ability and lowers to a decent height. It rides comfy too. I have mine set to '3' but before i would have it at 2 until everything broke in.
Old Oct 8, 2008 | 12:05 AM
racebum's Avatar
Default Re: (FuNkDrSpOt)
i'm amaized at the difference between the da and dc coils in the tokico kit. the da kit doesn't go down nearly as much as the dc kit.
Old Oct 8, 2008 | 03:36 AM
BoltonGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FuNkDrSpOt &raquo;</TD></TR><TR><TD CLASS="quote">I have the Eibach pro's and the Tokico. Nice setup. Provides extra cornering ability and lowers to a decent height. It rides comfy too. I have mine set to '3' but before i would have it at 2 until everything broke in.</TD></TR></TABLE>Thats exactly what i was aiming for. Daily comfort with autocrossability, my prokit/illuminas should be in by friday
Old Oct 8, 2008 | 05:27 PM
SleeperGSR's Avatar
Default Re: (BoltonGSR)
there was a good read in here about "adjustable" coilovers. Basically the long and the short of it, is that if you don't get a crazy expensive kit, the "adjustibility" isn't all that it is cracked up to be. I would have to say that im finding this holds true with the tokico's. I have the illumina coilover kit and notice that there is less difference between 1 and 3 than 3 and 5. Also, not real impressed with the spring rates, could be much stiffer of a set up. All and all a good daily setup, but a little lacking in dampening. Also, the way they adjust the ride height will change the dynamics of the spring. I wouldn't recomend these if you are planning on any suspension tuning.
Old Oct 8, 2008 | 05:32 PM
thabao's Avatar
get the illumina, i got the blues and wish i got the illuminas for the damper adjustments. blues are too soft for me.
Old Oct 9, 2008 | 12:01 AM
kelviiv's Avatar
https://honda-tech.com/zerothread?id=2404049
Old Oct 9, 2008 | 09:53 AM
racebum's Avatar
Default Re: (kelviiv)
it's the springs making the blues too soft. as for the OP, give them a shot, see what you think. once the car is on lowering springs they are easy to change out. i rolled on DC tokico springs for 6 months before i got tired of bottoming out and the understeer. a larger rear bar helps with a lot of it but i finally installed tein h techs. the fronts are only 50lb stiffer than tokicos but the rears are double. tokicos are around 120lb and the teins are around 250lb. we'll see how these work next week when i get my new motor in.
Old Oct 9, 2008 | 10:47 AM
BoltonGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idrivesideways &raquo;</TD></TR><TR><TD CLASS="quote">it's the springs making the blues too soft. as for the OP, give them a shot, see what you think. once the car is on lowering springs they are easy to change out. i rolled on DC tokico springs for 6 months before i got tired of bottoming out and the understeer. a larger rear bar helps with a lot of it but i finally installed tein h techs. the fronts are only 50lb stiffer than tokicos but the rears are double. tokicos are around 120lb and the teins are around 250lb. we'll see how these work next week when i get my new motor in. </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoltonGSR &raquo;</TD></TR><TR><TD CLASS="quote">Thats exactly what i was aiming for. Daily comfort with autocrossability, my prokit/illuminas should be in by friday </TD></TR></TABLE>
BoltonGSR
Jul 21, 2008 04:03 PM
IIVIIoOkY
Mar 30, 2006 09:29 AM
Drakko
Aug 25, 2004 06:12 AM
LudeAchris2001
Aug 19, 2003 10:18 PM
202B
Jan 22, 2003 09:43 AM
