Z6 Only 3 cyl fireing.....
Old Oct 5, 2008 | 05:53 PM
Stevens2266's Avatar
Default Z6 Only 3 cyl fireing.....
So my Z6 will only fire 3 cyl. wont fire the one on drivers side. ive replaced everything i could think of.... all but ecu and harness. compression is perfect and just put a new head on too... checked the voltage for the injector plug and its 11volts on and off. anyone have any idea what might be causing this problem? like i said ive tried everything i can think of and its not worked. any help would be great.
Old Oct 6, 2008 | 03:34 AM
anyone?
Old Oct 6, 2008 | 04:28 AM
champneys05's Avatar
did u check your distributer cap?
Old Oct 6, 2008 | 04:31 AM
ya ive tried 3 different dizzy's. a new head, plugs, plug wires, Injectors, fuel rail, intake mani.
Old Oct 6, 2008 | 02:20 PM
anyone have an idea? i tested the injector plug for the 4th cyl and it got 11 volts.
Old Oct 6, 2008 | 03:32 PM
-JSpecEk*9-'s Avatar
Default Re: (Stevens2266)
ok try swapping the bad injecter on to a different spot and see if the misfire changes over. if you have checked everything else then try a new injecter.
Old Oct 6, 2008 | 04:21 PM
bigD's Avatar
did you remove your ecu at all, I was having a problem with one of my injectors and it ended up being a pin was not getting a good connection at the ecu.
Old Oct 6, 2008 | 05:10 PM
ive tried the switch. i have brand new ones in it now. ill try the ecu thing. so you just unplugg it and replugg it?
Modified by Stevens2266 at 4:03 AM 10/7/2008
Old Oct 11, 2008 | 11:28 AM
replaced intake mani and fuel rail today and nothin has changed 4th cyl still wont fire. i switched the 4th adn 3rd injector wires and wtill no fire from the 4th cyl. anyone have an idea?
Old Oct 12, 2008 | 09:31 PM
anyone have a clue?
TwoKSiR
Sep 14, 2010 03:25 PM
V3locity
Dec 21, 2009 05:52 PM
ctr32
Sep 29, 2009 07:33 AM
rad32
Aug 4, 2009 05:24 PM
EGdaveoner
Jun 14, 2005 10:13 PM
