when should i change spark plugs?
Old Oct 5, 2008 | 11:49 AM
skaternak's Avatar
Default when should i change spark plugs?
how often do you change them?
Old Oct 5, 2008 | 12:33 PM
turbojdmhatch's Avatar
Default Re: when should i change spark plugs? (skaternak)
check them every couple of months or whenever u feel like your motor isnt running like u think it should
http://www.spark-plugs.co.uk/p...s.htm
how to tell how ur motor is running by the spark plug
honda.lioness's Avatar
It's in your owner's manual. If you do not have an owner's manual, then go to https://techinfo.honda.com/rjanisis/logon.asp. On the left, click on "Owner's Manuals." Follow the pointers. Once you arrive at the pdf file, it may appear that only one page has come up. In fact, page numbers that are highlighted within the pdf file are links on which you can click to take you to the page. Also, in the upper right hand corner of any white page look for an arrow. Click the right arrow to get to the next page. Lastly, pressing "Ctrl-A" will permit easier reading of some of the pages at this site.
Use only the spark plug brand your owner's manual recommends. Doing otherwise can hurt performance.
Old Oct 5, 2008 | 01:18 PM
EJ8_Enthusiast's Avatar
ncie link on the spark plugs turbo..
Old Oct 5, 2008 | 01:38 PM
Kista20's Avatar
generally speaking with honda's and almost every other manufacturer that recommends the standard conventional plugs is 30k miles.
Old Oct 5, 2008 | 02:03 PM
since they are like 10 bucks a set for NGK, taking 15 minutes once a year to change them shouldn't even be a question.
Thrillhouse
Apr 14, 2003 10:21 AM
wizzards581
Mar 12, 2003 08:38 PM
sslude
Jan 20, 2003 08:05 PM
HondaRcB
Aug 15, 2002 12:31 PM
HondaJon
Jul 28, 2002 05:10 PM
