check spark plugs???
Old Jan 9, 2003 | 05:21 PM
sslude's Avatar
Default check spark plugs???
how do i check them. i am not mechanically inclined. can i just pop the hood (at any given time) and takt the spark plug cover off and take the spark plug out?
Old Jan 9, 2003 | 07:00 PM
sslude's Avatar
Default Re: check spark plugs??? (sslude)
anyone?
Old Jan 9, 2003 | 07:05 PM
Nite's Avatar
Yea just make sure the car is turned off
Old Jan 9, 2003 | 09:22 PM
Malgerus's Avatar
Default Re: check spark plugs??? (Nite)
They should be a light brown in colour. Through the spark plugs you can read how the engine is running. Like a whitish colour denotes too much heat, etc.
Old Jan 10, 2003 | 03:11 AM
88_SC_CRX_Si's Avatar
New User
Just make sure the engine is cold... Otherwise you take a chance of pulling the threads out of the head, along with the plug. Unless there has been Anti-Seize put on them.
Here is some info on reading them..
http://www.ngksparkplugs.com/techinf...q/faqread2.asp
Old Jan 10, 2003 | 02:42 PM
sslude's Avatar
Default Re: check spark plugs??? (88_SC_CRX_Si)
are ther any bolts that i need to take out (besides the spark plug cover)? so i take thecover off, then just pull it out? and what do you mean if it has anti-seize on it?
Old Jan 19, 2003 | 09:19 AM
nfn15037's Avatar
If taking out sparkplugs is so complex you have to ask, please do yourself a favor and purchase a Helms manual. It will save you lots of time and $. Oh and as for the plugs, just take thge cover off and remove the wire and take them off 1 AT A TIME, else you will not know what wire goes to what plug, unless of course you have a Helms
Old Jan 19, 2003 | 04:56 PM
Casual Gcode1's Avatar
Default Re: check spark plugs??? (nfn15037)
Where can you get a helms manual from?
Old Jan 20, 2003 | 08:05 PM
myhatchrips's Avatar
what do you mean make sure the engine is cold? isnt cylinder compression checked with the engine at normal operating temperatures? therefore i say let the motor cool for 5 to 10 minutes and then pull those plugs out. no need to wait till the engine is cold.
Former User
17
Aug 19, 2016 09:34 AM
b20bFourDoorCivicLX
Mar 16, 2012 10:26 PM
Lithel
Dec 9, 2008 09:09 AM
GTCX94
Jan 20, 2004 12:07 PM
