cam gear teeth and ignition timing (h22a)
Old Jul 27, 2002 | 03:39 PM
Mover's Avatar
Default cam gear teeth and ignition timing (h22a)
How many teeth does a 4th/5th gen h22a cam gear have ?
I'm trying to figure out what effect misaligning the timing belt on a cam gear by one tooth has on ignition timing. ( 1 tooth = deg crank ?)
Put everything back together after doing a cam swap and found the igintion timing retarded 4 deg even when realigning the distributor with white out.
[Modified by Mover, 7:49 PM 7/27/2002]
Old Jul 27, 2002 | 05:01 PM
Chiovnidca's Avatar
Default Re: cam gear teeth and ignition timing (Mover)
If I remember right, one tooth will cause the ignition timing to be off 12 - 16 degrees. The 4 degrees you are off are probably from the two cams being phased a little differently.
Old Jul 27, 2002 | 08:34 PM
minime's Avatar
Default Re: cam gear teeth and ignition timing (Chiovnidca)
should be about 15 degrees per tooth.
Old Jul 30, 2002 | 06:40 AM
Mover's Avatar
Default Re: cam gear teeth and ignition timing (minime)
Thanks for all the help guys... I counted the teeth on my cam sprocket (42)
Turns out 1 tooth = 17 deg
Old Jul 30, 2002 | 06:57 AM
2point6's Avatar
Why would your ignition be retarded by swapping just cams? Unless the marks were not aligned correctly when you put the timing belt back on or are the cam lobe centers different than the stock? Is the distributor groove cut differently? Did you get your head milled as well? Just curious.
Old Jul 30, 2002 | 09:03 AM
Mover's Avatar
Default Re: cam gear teeth and ignition timing (2point6)
Good question ? I'm kinda surprised myself why it was 4 deg retarded.
A little background. I was swapping out the stock cams for some after market ones. I set the timing about a year ago with a timing light (15 deg) and marked the distributor with whiteout to make sure it didn't shift in timing.
The aftermarket intake cam snapped at the cam gear...(lucky no valve damage) so we reinstalled the stock cams.
Checked the ignition timing and found 10-11 deg. The distributor white out marks didn't move. BTW.. head wasn't milled.
I didn't think that timing belt stretch would retard the cams/ignition timing by that much (4 deg) !! I'll be rechecking the crank TDC mark with the cam gear marks to make sure everything lines up (therefore ruling out TB stretch)
Any thoughts ?
[Modified by Mover, 1:57 PM 7/30/2002]
Mr.Integra
May 22, 2003 12:41 AM
Jockobo
Jan 23, 2003 03:48 PM
Ignitecivic
Mar 15, 2002 12:32 PM
DaNish
13
Jan 24, 2002 12:00 PM
N1Spec
Nov 18, 2001 11:15 PM
