Oil On Back Of Flywheel.. Need New Crank Seal?
Specs: JDM 89 B16 Y1
I decided to put locktite on my flywheel bolts (I heard it wasnt neceeeary but might as well) before I put my new clutch on, when i looked at the back of the flywheel however, there was a little bit of (new) motor oil on it. Im assuming I need a new crank seal..
Is thos most likely my problem?
Can I just order one for a 99-00 si? or a VTEC DelSol?
thanks guys
thanks guys
When ever you do a clutch if you don't know when the last time was that your engine had a seal I put one in. You already there and they are so cheap.
It's almost always a good idea to change the rear main seal while you've got the flywheel off.
B/D/F/H-series engines pretty much all use the same rear main seal, 80x100x10. Part number 91214-PLE-003.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">It's almost always a good idea to change the rear main seal while you've got the flywheel off.
B/D/F/H-series engines pretty much all use the same rear main seal, 80x100x10. Part number 91214-PLE-003.</TD></TR></TABLE>
wow thanks alot man!
I installed a new one tonite, and I was wondering: should it be flush with the "cover" it sits in? or should it stick out a little?
thanks guys
thanks guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXdan »</TD></TR><TR><TD CLASS="quote">It needs to ride on a different part of the crank than it originnally did. Some seals are offset to compensate for this.</TD></TR></TABLE>
im not quite sure what you mean, but if you could elaborate that would be great
can anyone confirm this? the new seal seemed to be a tad bit shorter than the origional one, (depth wise)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicmulisha »</TD></TR><TR><TD CLASS="quote">i am pretty sure it should be pretty flush with the block </TD></TR></TABLE>
this is what I thought but I just wanted to be sure
thanks guys, keep the info comming!!
can anyone confirm this? the new seal seemed to be a tad bit shorter than the origional one, (depth wise)<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicmulisha »</TD></TR><TR><TD CLASS="quote">i am pretty sure it should be pretty flush with the block </TD></TR></TABLE>
I was looking to buy my rear main oil seal from advance... just making sure..this is the one I need right?
http://www.partsamerica.com/pr...40430
does it give dimensions?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">It's almost always a good idea to change the rear main seal while you've got the flywheel off.
I followed tese dims and it fits snug! its only $11 from honda online..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatcht9x »</TD></TR><TR><TD CLASS="quote">does it give dimensions?
I followed tese dims and it fits snug! its only $11 from honda online.. </TD></TR></TABLE>
How long does it take to get to you though?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harmonator84 »</TD></TR><TR><TD CLASS="quote">
How long does it take to get to you though?</TD></TR></TABLE>
It takes no time at all to drop by the local Honda dealership parts department and ask for one.
$16.18 plus tax.
$16.18 plus tax.
$16.18 plus tax.</TD></TR></TABLE>
x2
and to answer your question, mine came within 2 or 3 days!
x2
Civic_95_Si
Jun 7, 2004 07:46 AM
altoid
Jun 22, 2003 07:08 PM
