gsr cluster in crx ?
Old Oct 4, 2008 | 02:13 PM
team2dcrx's Avatar
Default gsr cluster in crx ?
alright i have gotten pretty much everything to work like;
trunk open lght,gauge brightness, gauge lights,l turn signal,right turn signal,e brake light,battery light,cel,tach,oil pressure light........but when i actually turn the car on and hit a signal my tach goes bak and forth like its the turn signal....and i can get the fuel gauge or coolant to work.....
Modified by team2dcrx at 4:21 PM 10/19/2008
Old Oct 5, 2008 | 06:24 AM
team2dcrx's Avatar
Default Re: gsr cluster in crx ? (team2dcrx)
bump
Old Oct 5, 2008 | 06:31 AM
gunnerman's Avatar
there's a write on here somewhere about how to wire it up...i've seen a gsr cluster in an ef so it's possible. u should find it through a search.
Old Oct 5, 2008 | 07:29 AM
zccr-xsi's Avatar
https://honda-tech.com/zerothread?id=1732102
took me less then 5 sec to find.next time read though the civic & crx FAQ before posting!!
Old Oct 5, 2008 | 06:45 PM
team2dcrx's Avatar
fyi....i have everything done just as it says but i dont have a solid yellow on b4 its a yellow with blue and when i connect it to power the fuel guage goes all the way full and when i hit the signal<left or right> the hazards go on and the tach goes back and forth!!!!
Old Oct 5, 2008 | 06:52 PM
team2dcrx's Avatar
Default Re: (team2dcrx)
heres my table
88-Crx action integra
c4-yellow/white fuel guage yellow/white
d3- green/black Trunk open light green
c7-red/black Gauge brightness cont red
c6-red Gauge lights red/black
c1-green/blue Left turn signal green/blue
d8-green/yellow Right turn signal green/yellow
d4-green/red E-brake light green/red
c3-yel/green Coolant temp gauge yellow/green
c9-white/blue Battery light white/blue
c10-green/orange Check engine light green/orange
c11-blue Tach blue
d2-red/blue High beam red/green
c5-yellow/red oil pressure light yellow/red
c8-black/yellow Switched power black/yellow
d7-yellow Switched power yellow
d1-black Ground black
c2-blue Drivers seatbelt red/blue
Old Oct 5, 2008 | 07:08 PM
team2dcrx's Avatar
i have a 88 crx and i might be using the pinouts for a 91!!!!!
any one have the piouts for a 88 crx
Old Oct 6, 2008 | 06:18 AM
zccr-xsi's Avatar
have u ever thought of using the SEARCH BUTTON????
Old Oct 6, 2008 | 08:06 PM
team2dcrx's Avatar
well mr search...yes i did and there aint ****...in regards to a 88 crx
Old Oct 19, 2008 | 03:18 PM
team2dcrx's Avatar
bump
donaldmejr
19
Dec 12, 2009 02:02 PM
Whit3boy908
19
Sep 17, 2008 04:21 AM
anotherstar_noz
14
Jun 13, 2008 04:03 PM
mugenhatch92
Mar 30, 2006 12:26 PM
