Is this from an Integra or a Civic Si?
Old Oct 2, 2008 | 09:55 AM
jdm_vizionz's Avatar
Default Is this from an Integra or a Civic Si?
I took this to the Honda dealership and went to the parts department, and they said they couldn't find it. And said since it was a swap, it might be from an Acura. It has to do with the power steering in the tranny. A guy that rebuilds trannys said it was the Variable assist unit but I can't seem to find one for sale at all. It was in My B16 tranny which was on my B18c. Can Anyone help me with this?
Old Oct 2, 2008 | 10:18 AM
HONDRETTI's Avatar
Default Re: Is this from an Integra or a Civic Si? (jdm_vizionz)
its a vehicle speed sensor (VSS) and its from an integra, 90-93. it sits/bolts into the top of the tranny, and enables you speedometer to work, and VTEC. it could also work for a civic, but ive never owned one. it operates with a speedo cable that plugs into the big hole on top and then into the back of the inst. cluster. 2 power steering lines connect into it also, like you said.
i had one just like it in my b16 when i did my swap, when it was stolen
Old Oct 2, 2008 | 12:26 PM
Is it only from a 90-93 integra? Or does the newer years have it too?
Old Oct 2, 2008 | 02:23 PM
HONDRETTI's Avatar
Default Re: (jdm_vizionz)
newer years use a vss but its an electronic vss, transmitting a signal to the ecu. i would assume only obd0 cars would use the one you have, someone correct me if im wrong...
what year/car do you have? what are you trying to do with it?
Old Oct 2, 2008 | 02:34 PM
vtecallday's Avatar
Default Re: (HONDRETTI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDRETTI &raquo;</TD></TR><TR><TD CLASS="quote"> i would assume only obd0 cars would use the one you have, someone correct me if im wrong...</TD></TR></TABLE>
90-91 is obd0 and 92-93 integra is obd1 and they use it too... that speedo sensor is used with cable trans, hydro trans uses the electric ones
Old Oct 2, 2008 | 02:40 PM
HONDRETTI's Avatar
Default Re: (vtecallday)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecallday &raquo;</TD></TR><TR><TD CLASS="quote">
90-91 is obd0 and 92-93 integra is obd1 and they use it too... that speedo sensor is used with cable trans, hydro trans uses the electric ones </TD></TR></TABLE>
thats what i meant to say
Old Oct 2, 2008 | 02:47 PM
vtecallday's Avatar
thats what i meant to say </TD></TR></TABLE>
werd
Old Oct 2, 2008 | 06:24 PM
My B18c with the B16 tranny used to sit in an '88 CRX Si. I sold the crx shell, and yanked out the Motor and tranny. I think he converted it from obd0 to obd1. And then my dad looked at it and it has a crack it in. I just wanted to throw it back on the B18c and throw the motor into my 94 Integra LS.
Old Oct 2, 2008 | 06:35 PM
If I can't find one, will the Stock 94 LS one work or do I need an Si or GSR one for it to work?
Old Oct 2, 2008 | 07:31 PM
Horseofcourse's Avatar
well since its from a cable tranny, and its a cable tranny VSS. The car you own(94 teg) is setup for the use of a Hydraulic transmission. You will need to get a whole new Transmission and VSS to make the swap into your integra
witemice
Feb 15, 2011 10:41 AM
houseofgrafix
Aug 5, 2010 06:27 PM
alscrx
Jun 14, 2007 08:50 PM
honDA16
Nov 8, 2004 02:44 PM
keebler65
Mar 31, 2002 01:04 PM
