changing transmission fluid
Old Oct 2, 2008 | 09:00 AM
ejpogi1925's Avatar
Default changing transmission fluid
how do you change the transmission fluid on a 1993 civic dx hatchback? tried searching but all that comes up are for cars with a manual tranny. doesn't anyone have any care for automatics anymore?
pictures would help a lot. thanks!
Old Oct 2, 2008 | 11:15 AM
ejpogi1925's Avatar
Default Re: changing transmission fluid (ejpogi1925)
don't just look.... please help me....
Old Oct 2, 2008 | 11:17 AM
guinnessstout's Avatar
same concept pull drain plug and drain, fill through dip stick hole. easy
Old Oct 2, 2008 | 11:23 AM
riceburnerryan's Avatar
or you can fill through the VSS, or i believe there is a fill bolt that you take out and fill through there
Old Oct 2, 2008 | 12:43 PM
ejpogi1925's Avatar
Default Re: (riceburnerryan)
can you tell me where the vss is located? it's my first time changing transmission oil.
Old Oct 2, 2008 | 01:18 PM
Default Re: (ejpogi1925)
its an auto,
just fill through the dip stick tube with a funnel. it is under the intake tube on back side of trans. it takes 2.7-2.9 qts. You use the VSS fill when it is a manual trans.
Old Oct 2, 2008 | 01:57 PM
ejpogi1925's Avatar
Default Re: (guinnessstout)
thanks but do you know where the drain plug is? thanks again.
Old Oct 2, 2008 | 03:08 PM
the drain plug is in the bottom of the trans the head of the bolt is 3/8" square drive. On the side of the trans by the engine oil pan sorry not pic's.
frossteedhehe
Transmission & Drivetrain
Feb 14, 2013 01:07 PM
sublimeh215
Mar 24, 2009 04:39 PM
Understeer
Mar 19, 2004 09:59 AM
mickey513
Acura TL, RL & ZDX
Apr 24, 2003 01:48 PM
4doorLX
Oct 2, 2002 10:55 AM
