H22A SMSP vs. Hytech Header???
i would like to buy a new header for my new engine, but which one is the best:
i need good power from 5500-8200 (max. 8500) rpm and max torque
facts from my engine:
Skunk2 Pro2 cams
ENDYN welded head
EURO R Manifold ported and welded by ENDYN
70 TB
GE sleevet block
ENDYN Roller Wave piston
89,5 bore
12,0:1 cr
and and and
i hope for 300PS+ and 270NM+ (about 250whb and 200lft)
my old Hytech:
SMSP Stage 4
what are your recomending?
thanks a lot for help
Skunk2 Pro2 cams
ENDYN welded head
70 TB
GE sleevet block
89,5 bore
12,0:1 cr
and and and
my old Hytech:
SMSP Stage 4
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garrett »</TD></TR><TR><TD CLASS="quote">the only way to know
try both on the dyno</TD></TR></TABLE>
fixed
fixed
I think they will be very close, maybe with a small advantage to the Hytech.
I have run the Hytech header and when I put it on together with the Euro R intake manifold I gained 24 hp.
You could also consider getting the Six Sigma Racing header, it seems to be good header and I think the delivery time is much better than SMSP and Hytech.
Don’t bee disappointed if you don’t get 300 HP, I think it is very hard to get on the 90,7 mm crank.
PWL
PWL
Interesting info in this thread.
Here's a H22 with Type S pistons, a $500 valve job, Jun cams, no bal shafts, Euro R IM and ITR TB.
232whp @ 7500 rpm, BTW this is with my Stage 2 header.
Modified by SMSP at 6:52 PM 10/2/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMSP »</TD></TR><TR><TD CLASS="quote">Interesting info here.
OP has a larger displacement, bigger cams, bigger TB, higher compression, and ENDYN headwork. I see no reason this motor shouldn't hit 250whp with one of Jon's headers.
</TD></TR></TABLE>OP has a larger displacement, bigger cams, bigger TB, higher compression, and ENDYN headwork. I see no reason this motor shouldn't hit 250whp with one of Jon's headers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2LEM1 »</TD></TR><TR><TD CLASS="quote">
OP has a larger displacement, bigger cams, bigger TB, higher compression, and ENDYN headwork. I see no reason this motor shouldn't hit 250whp with one of Jon's headers.</TD></TR></TABLE>
any of them properly made for the engine will make great power. You cant go wrong with any of them.
so whats going to happen if this motor doesnt hit 250? what else are you going to be able to judge the engine by?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">
so whats going to happen if this motor doesnt hit 250? what else are you going to be able to judge the engine by?</TD></TR></TABLE>
I approoved all your statement
it's really easy to go wrong
power don't always grow up
thanks guys for your help and infos
i was allways a Hytech fan but the delivery times make me really angry
five headers and always 5-7 month; guaranteed 2-3 weeks
so i look at a new company and my favorit is SMSP!
john would make a three step instead of a two step.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hingi »</TD></TR><TR><TD CLASS="quote">thanks guys for your help and infos
I thought you already had the Hytech. In that case, go with the SMSP.
pcguy760
Jul 31, 2006 03:43 PM
imagineengineering
Apr 11, 2003 05:28 PM
