how do i put a/c on my eg gsr swap
Old Oct 1, 2008 | 07:25 PM
allgonoshow808's Avatar
Default how do i put a/c on my eg gsr swap
im kinda lost and never done this before please give your advice. what do i need?
Old Oct 22, 2008 | 03:26 PM
mikeledez's Avatar
Default Re: how do i put a/c on my eg gsr swap (allgonoshow808)
for real i want to know too
Old Oct 22, 2008 | 10:21 PM
alpha_1's Avatar
use all the ac lines from the 92-00 civic including the ac pump and b-series bracket unless you can find the 99-00 civic SI pump and bracket. the 99-00 civic SI pump must still retain the two top hoes for it to work. the 92-95 ac pump will work as well but will only be held up by two bolts and not all four. your going to have to use the top and bottom right bolts only(the bolts closet to all the belts or by your driverside headlights) and the not the two top and bottom left bolts. it works fine trust me. 92-93 will need r12 freeon unless your convert to r134 and the 94-00 civic ac pump will need r134 freeon. good luck
Honda_Cribb_GS-R
Jun 3, 2009 06:11 PM
thumper64
Jan 30, 2009 10:40 AM
turbotime
18
Sep 6, 2005 02:48 PM
madman604
Sep 23, 2003 11:21 AM
civichbdx
Oct 28, 2002 03:47 PM
