Injector Install HELP ASAP
Found out that one of my injectors is leaking. Was planning to do a MINI-ME but now I see I need to install these new injectors since one is leaking.
My haynes manual is gone missing, and I have searched but cannot find a clear cut answer of how to do the install.
Some say you need a lube to get the the injectors.
Can anyone give me a answer if anything extra is needed to install them.
THANKS IN ADVANCE
THANKS IN ADVANCE
just pull the fuel rail pull the old ones out and use a little oil or silicone spray on the o-rings. Main word here is little. push the injectors in and put the stuff back together. nothing to it
