Gsr ignition timing....cant find mark on cover?
Old Oct 1, 2008 | 01:12 PM
mortificationrock's Avatar
Default Gsr ignition timing....cant find mark on cover?
ok well I was trying to do the timing on a obd2 gsr in my ek. when I start looking for the V thing on belt cover there aint nothing there to align my timing. what gives?
Old Oct 2, 2008 | 10:42 AM
Default Re: Gsr ignition timing....cant find mark on cover? (mortificationrock)
Bump no replies in one complete day?
Old Oct 2, 2008 | 11:03 AM
SilverAWD's Avatar
What does your ignition timing have anything to do with your belt cover? You are talking about loosening the bolts on your distributer and adjusting your ignition timing that way right?
Old Oct 2, 2008 | 12:50 PM
Default Re: (SilverAWD)
correct but on my d16y8 on the cover of the t belt there is the v thing that you use to align or point the gun at while adjusting the ignition timing. on my gsr I see nothing like it. so therefore I can't adjust my timing.
Old Oct 2, 2008 | 07:31 PM
geebs's Avatar
Default Re: (mortificationrock)
No mark on the cover? did it get taken off?
Old Oct 3, 2008 | 01:29 PM
Default Re: (geebs)
I don't know......really. It might be missing or I misseed it myself. does anyone have a pic of its location? Should it be in the same location as a d series?
Old Oct 3, 2008 | 05:38 PM
geebs's Avatar
If you're looking down at the crank pulley, while standing infront of the car, it should be slightly towards you, on the plastic cover.
Old Oct 17, 2008 | 01:46 PM
Default Re: (geebs)
Anyone have a pic of what it looks like?
Old Oct 18, 2008 | 01:33 PM
EF9status's Avatar
If not just remove the spark plug from cylinder 1 and stick a long screwdriver in and slowly bring the piston up until there is no more movement and then line up the cam gear
averyvm
Jun 22, 2010 08:33 AM
bo0oost
Aug 18, 2007 09:32 PM
Honda Kustums
Aug 19, 2003 06:36 PM
Brian_92GSR
Aug 19, 2002 07:23 AM
