94 civic with 97 gsr swap i need sumhelp doods!
Old Oct 1, 2008 | 04:34 AM
waterfordtuners's Avatar
Default 94 civic with 97 gsr swap i need sumhelp doods!
i just bought a 94 civic with a 97 gsr swap. the motor is stock but header and exhaust. it comes with the obd1 p28 ecu. when vtec kicks in it doesnt make a difference or at least i cant feel the difference so i was wondering would the p72 make alot more of a difference because vtec is pretty weak rite now. i have the obd2 p72 ecu but the cars harness is obd1. king motorsports said i cant just get a conversion harness they said i have to do a bunch of other **** too so idk what to do. is it worth finding a 0bd1 p72 or what
Old Oct 1, 2008 | 04:49 AM
bigD's Avatar
get your p28 chipped for a gsr.
Old Oct 1, 2008 | 04:51 AM
i_am_a_black_man's Avatar
Default Re: 94 civic with 97 gsr swap i need sumhelp doods! (waterfordtuners)
check if the p28 is chipped or virgin to begin with
Old Oct 1, 2008 | 04:58 AM
Default Re: 94 civic with 97 gsr swap i need sumhelp doods! (i_am_a_black_man)
its virgin
Old Oct 1, 2008 | 10:30 AM
Vindicator9000's Avatar
318 Curves, 11 miles
Think it's a gsr thing. I have a gsr swap with the p72, and vtec crossover is not as noticable as on a b16. It's more noticeable when the intake secondaries open up.
Which leads me to this - On a gsr, with a P72, vtec crossover is only at like 4600 rpm, which is much lower than a stock p28 crossover. Also, if you're using a P28 on a gsr head and intake manifold, your IABs are not working - they should open at like 5800 rpm. Which doesn't really matter because they default to open, but you'll get a little better low end with a p72 and IABs working.
Therefore, for best results, you should either get your p28 tuned for a gsr, or put the p72 in.
Old Oct 1, 2008 | 11:33 AM
Default Re: 94 civic with 97 gsr swap i need sumhelp doods! (Vindicator9000)
thanks for the help doods
Old Oct 1, 2008 | 01:05 PM
1SIKZ06's Avatar
A chip should solve your issue
OrtizNwk
Dec 30, 2012 06:29 PM
93bubble87
Engine Management and Tuning
11
Jan 5, 2010 07:59 PM
eggsi619
Aug 18, 2009 12:36 AM
JaydmEg
24
Nov 29, 2008 02:37 PM
maxheat
10
Feb 9, 2005 12:55 PM
