Seafoam
A week ago my car had a rough idle and thought the fuel injectors was dirty so i poured half a can of seafoam into the gas tank with just a lil more of 3/4 of gas and it was fine ever since and today it was acting up and now my car doesn't start.
changed rotor, distributor cap, sprak plugs and spark plug wire
I've been starting it many times, and sometimes it would sound it'll turn on but no luck please help
ope another hawaii sedan!
but sorry i dont have the answer to your question
ive seafoamed like 3 or 4 cars with no problems at all...
so it would crank but not start or...?
Modified by nomoshing at 9:38 PM 9/30/2008
Connect a spark plug to the spark plug wires, hold the spark plug wires with rubber handle pliers and hold the tip of the spark plug near the motor block, have someone crank motor. If you see no spark, most likely it's you ignitor or coil, or both.
If you have spark when cranked, put the tip of a flat head screw driver to the body of the injector and put your ear to the handle end of the screwdriver and have a friend turn the key to "II" back and forth slowly and see if you can hear a small click noise. If you do not hear the click noise, your injectors are not firing.
https://honda-tech.com/zerothread/1998336
should have went there and under <U>Engine</U> it says "seafoam DIY instructions and how-to"
Trbospnkr
Dec 29, 2003 09:46 AM
