TDC???????
Old Sep 30, 2008 | 12:44 PM
thebleek's Avatar
Default TDC???????
Okay, so i got a d16y8 head in the mail and it wasnt at TDC
so im rotating counter clockwise and when the UP marking on the cam gear is 100% UP [TDC] the valves for the 2&3 cylinder is opening
i thought the 1 or 4 would be opening because of the intake and exhaust compression stroke right?
or do 2&3 open and im just a astupid *** that never knew that?
Old Sep 30, 2008 | 12:59 PM
thebleek's Avatar
bumped to the top, for a car on jacks!
Old Sep 30, 2008 | 01:08 PM
Luke_V-tec's Avatar
Default Re: (thebleek)
TDC is just before the piston starts to travel back down the bore on its power stroke as the spark plug has ignited the fuel and air mixture, no valves should be open on 1 at this stage.
Old Sep 30, 2008 | 01:09 PM
Frickr's Avatar
tdc is measured off the #1 cylinder. which would just be starting the power stroke. while the #3 and #4 pistons will be on the intake and exhaust stroke.
Old Sep 30, 2008 | 01:56 PM
thebleek's Avatar
actually my cylinder 2 & 3 were open.
one was on intake one was on exh
is that bad?
Old Sep 30, 2008 | 02:06 PM
thebleek's Avatar
Old Sep 30, 2008 | 02:25 PM
thebleek's Avatar
Old Sep 30, 2008 | 09:06 PM
geebs's Avatar
2 and 3 will be open, and 1 and 4 will be closed, at TDC.
No cylinders should be at the same position. So 2 being on intake, and 3 being on exhaust is normal.
Old Oct 2, 2008 | 07:26 AM
SIRIUS VTEC's Avatar
hmm thanks for the info, i needed to know that.
94lsrhd
Jun 13, 2009 05:55 PM
thebleek
Oct 1, 2008 08:03 AM
Combustion Contraption
34
Jan 20, 2007 10:59 AM
TeamCracka
Feb 6, 2004 07:01 PM
McDade
Jan 23, 2003 03:34 AM
