My horn quit working... need help
ok well i had to replace the knuckle joint in my steering colum so i droped the steering colum and replaced it. but after i had put it all back together the horn didnt work anymore. so i took it apart and looked though everything and i can figure out why i dosnt work.
any ideas would be greatly apreciated...
Is your SRS light also on?
Do your brake lights still work?
You may have broken the cable reel/clock spring inside of the steering wheel, or you popped the horn/stop fuse.
um yea my yellow srs plugs r all pluged in... i trouble shooted though thr wireing and figured out that the plug conected to the botom of my stering wheel had been pulled and the conectors where broken.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eesuh »</TD></TR><TR><TD CLASS="quote">wtf does SRS stand for, that light is on in my car to lol</TD></TR></TABLE>
SRS is the system for you airbags. thats why its says srs on ur airbags.
o and my light dosnt turn on b/c i took the bulb out bc i dont have a passenger airbag...
but i figuered it out anyways. thanks for the sugestions though.
o and the funny thing is... i have wireing for an alarm in my car and i just found the brain for it under the dash today. lol. so now i just have to my and get the remote for it. lol
Did someone play "Wheel of Fortune" with your steering wheel while you had it disconnected from the rack? If so, you probably have a broken clockspring since the SRS light is on AND the horn doesn't work AND you say that the plugs are plugged in.
PA MATT
Nov 20, 2003 11:40 AM
