wiring problem
if you want to run it without vtec you can but it will still run choppy...if you do this you will also need to use the intake manifold from your 91 motor
i left the the intake manfold on there and on the back i think two or one of them just has a cap but i have like 2 left not hooked up
you will need a 94/95/96(must be same motor setup) to reference from as this will help alot....i own a 92 and a 96 so this was easier for me...there were a few vacuum lines that gave me some trouble but in the end i did get them done....one i had trouble with was a vacuum line that drops down to the rear motor mount
i have the same thing i have both cars but the 96 was auto so i had to get a tranny and the car didnt come with a vtec ecu and wiring harnness so i made my 91 wiring harnnes to work on it but i dont know what to do from here
the 91 ecu will run the engine fine but is not compatible with vtec....if you have and auto you need a p0A(i believe) ecu for the vtec....i got a used one on ebay and it came with the transmission computer for about 60 bucks + shipping ....goodluck
thanks um so you would take 60 for the computer and everything i hope thats the only thing to do but there is one plug thats not pluged in and the the plug under the vtec plug how can i do that
ceamodt
Apr 4, 2006 01:30 AM
