wiring problem
Old Sep 30, 2008 | 08:44 AM
AccordNation's Avatar
Default wiring problem
ok i put a vtec motor in my 91 accord got my factory wiring harness hooked up well my vtec computer got stolein can i use my sohc computer
Old Sep 30, 2008 | 08:53 AM
bseriescrxsi's Avatar
Default Re: wiring problem (AccordNation)
if you want to run it without vtec you can but it will still run choppy...if you do this you will also need to use the intake manifold from your 91 motor
Old Oct 1, 2008 | 01:30 PM
Default Re: wiring problem (bseriescrxsi)
i got it hook up and everything but there is the valcum lines i dont know were to put them
Old Oct 1, 2008 | 08:08 PM
what vacuum lines...i did this swap last year and all vacuum lines lead somewhere
Old Oct 2, 2008 | 02:14 AM
i left the the intake manfold on there and on the back i think two or one of them just has a cap but i have like 2 left not hooked up
Old Oct 2, 2008 | 10:34 PM
you will need a 94/95/96(must be same motor setup) to reference from as this will help alot....i own a 92 and a 96 so this was easier for me...there were a few vacuum lines that gave me some trouble but in the end i did get them done....one i had trouble with was a vacuum line that drops down to the rear motor mount
Old Oct 3, 2008 | 09:35 AM
i have the same thing i have both cars but the 96 was auto so i had to get a tranny and the car didnt come with a vtec ecu and wiring harnness so i made my 91 wiring harnnes to work on it but i dont know what to do from here
Old Oct 3, 2008 | 10:30 AM
the 91 ecu will run the engine fine but is not compatible with vtec....if you have and auto you need a p0A(i believe) ecu for the vtec....i got a used one on ebay and it came with the transmission computer for about 60 bucks + shipping ....goodluck
Old Oct 3, 2008 | 01:34 PM
thanks um so you would take 60 for the computer and everything i hope thats the only thing to do but there is one plug thats not pluged in and the the plug under the vtec plug how can i do that
Old Oct 3, 2008 | 10:27 PM
i got mine for 60 your going to have to look around.....mine is currently being used in my build....but you can find them for decent prices
Old Oct 4, 2008 | 09:23 AM
alright i look around and see what i can find so u think it would run alright for now?
K1llaturtl3
Dec 5, 2011 11:20 AM
WeB
Jan 28, 2010 06:58 PM
yhonda
Aug 22, 2009 02:03 PM
Pontas
Sep 11, 2008 03:48 PM
ceamodt
Apr 4, 2006 01:30 AM
