gsr swap in ef
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jpnolan »</TD></TR><TR><TD CLASS="quote">dpfi to mpfi. search that</TD></TR></TABLE> +1 obd0 + obd1 swap.
https://honda-tech.com/zerothread?id=131949
if that is not enough look here
https://honda-tech.com/zerothread/1508680
that should be enough info if not try searching everything is out there u just got to look
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d.fleezy »</TD></TR><TR><TD CLASS="quote">so I would need an obd0 to obd1 harness and injectors so far what else if anything. what wire harness do I need</TD></TR></TABLE>
always use the harness that came with the car chassis, then modify the harness to work with the new motor. There are detailed how-to's in the FAQ and in the archives if you search.
If your not comfortable doing your own wiring, you can send your stock harness out to Rywire and they will make it plug and play.
You can also get an OBD0 to OBD1 jumper harness and that will take care of all your wiring.
Other components you'll need:
-Mounts
-Shift Linkage
-ECU
-Axles
http://www.norcalcrx.org/dropp...p.htm
http://www.norcalcrx.org/dropp...t.htm
Modified by gursh d at 11:40 AM 9/30/2008
-Mounts
-Shift Linkage
-ECU
-Axles
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d.fleezy »</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ozzman3k3 »</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
what?
use the search feature, and the FAQ. If you still have a question, search again.
Then come back to the thread and ask questions, not just a simple 'bump'.
I did this swap last year and had no problems. I searched, read the FAQ, and used droppedcrxsi.com web page. Things went fine.
What else do you want to know?
what?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gursh d »</TD></TR><TR><TD CLASS="quote">
what?
What else do you want to know?</TD></TR></TABLE>
AMEN
what?
AMEN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad »</TD></TR><TR><TD CLASS="quote">
AMEN
A pal dropped one in his 89 hf and I'd have to say it is well worth it.Oh and if you read the FAQ on here you wont have to ask any more questions.It is fairly simple.
But only if you know what your doing.
AMEN
</TD></TR></TABLE>A pal dropped one in his 89 hf and I'd have to say it is well worth it.Oh and if you read the FAQ on here you wont have to ask any more questions.It is fairly simple.
Jax4gencivic
22
May 6, 2005 09:56 AM
