T25 Thread sizes for stock Oil Lines
Anyone know what the thread type is and size and all for the stock oil line fitting on a T25 off of an second gen. Either one, the one on the stock oil line, or directly into the housing, I just need to find out what I need on the end of my feed line.
Thanks
Jim
Thanks
Jim
Its a special metric fitting that you will probably not find anywhere, I have done many custom DSM turbo setups, the best way to get that fitting is go to the dealer and get that banjo bolt with oil feed line.
Another option is to tap out that fitting for an -AN fitting
Jeff
Jeff
Hi, this is my stock hard oil line connected to my T25.
Since everyone says that if I were to use a male fitting to thread directly into the T25 the threads are 7/16" inverted flare. Since I need a female fitting, can I use this brake adapter -3AN male to 7/16" female Inverted Flare ?:
EAR-989549
EAR-989549
Simple...
XRP fitting (like Earl's) - get the 7/16 IF to AN4 (inverted flare - like mentioned
above) and then get AN4 line...I used a 90 degree fitting (AN4 female - male
swivel) and works perfect...don't forget a washer if anyone plans on doing this.
Jason
https://honda-tech.com/zerothread?id=429527
Jason
One more thing, if you plan on fittings for the water lines, they are 14.5mm I believe...pretty easy to get - barbs, etc...
The 14B has a different fitting - Use the solex/dellorto carb fitting from Earls,
XRP... M12.5 for the oil inlet
The oil outlet is not threaded...
How much oil is coming out of the oil feed line and how fast? and if my return is the same size as t
seeeya04
Dec 7, 2005 01:18 PM
