90 Crx Si w/b18c Swap Map Sensor Question.
Helping a friend get his car running b/c he got deployed over seas.
It is running on a jdm pr3, car is still ob0.
Motor is a b18c swap.
I was told the map sensor was a firewall mount, and brand new is expensive.
Will other year Honda maps fit this car? If so what years?
Thanks in advance!!
Thanks in advance!!
theres a map sensor on the firewall for the stock engine, there should also be a map sensor on the throttlebody. you can unclip the wires from the map sensor on the firewall and connect it to the tb map sensor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickid03 »</TD></TR><TR><TD CLASS="quote">theres a map sensor on the firewall for the stock engine, there should also be a map sensor on the throttlebody. you can unclip the wires from the map sensor on the firewall and connect it to the tb map sensor.</TD></TR></TABLE>
There isn't a map on the throttlebody. I don't know what IM/TB combo is on there, but there isn't a map sensor present.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16SiHatch »</TD></TR><TR><TD CLASS="quote">just connect the map to one of the vaccum lines on the intake manifold. same way it was done on the original d16a6</TD></TR></TABLE>
I don't have a map sensor. The question I asked is "What OTHER sensors will work for this motor/ecu combo?"
pretty much all map sensors from honda are the same, but if u dont have a spot for a map sensor on the TB then u need to get one from an EF which is on the firewall
Plugs are gonna be different, but the wires are the same?
I am sure I can round up something.
Even if I don't have a spot for it on the manifold, I could run a vacuum line to it I'd figure?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickid03 »</TD></TR><TR><TD CLASS="quote">pretty much all map sensors from honda are the same, but if u dont have a spot for a map sensor on the TB then u need to get one from an EF which is on the firewall</TD></TR></TABLE>
true... does anyone have a diagram for the MAP sensor vacuum lines. same set up.. obd0 in an ef. thanks
