Quick year/engine question..
Old Sep 27, 2008 | 01:11 PM
Jimmy's Avatar
Global Moderator
Default Quick year/engine question..
i've got a 91 civic dx hatchback..
it's got a carb'd d15b8 in it..
Correct me if i'm wrong, but the '91 civic's didn't come carb'd did they?
Trying to figure out what year model engine i have.. so i can order a carb rebuild kit or maybe just go to the junkyard and pick another up..
thanks in advance..
Old Sep 27, 2008 | 01:25 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: Quick year/engine question.. (Jimmy)
No not in the US.
Are you sure it's carbed and not DPFI it's a fairly common mistake.
Old Sep 27, 2008 | 01:29 PM
sleepingciv's Avatar
Default Re: Quick year/engine question.. (***$nyper)
got a pic
Old Sep 27, 2008 | 01:31 PM
Jimmy's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ***$nyper &raquo;</TD></TR><TR><TD CLASS="quote">No not in the US.
Are you sure it's carbed and not DPFI it's a fairly common mistake.</TD></TR></TABLE>
You might be right..
I'll be more than willing to take a pic if you guys think it will help..
I cannot get this car to run right.. It only wants to run/drive at 3/4 throttle.. if you go full throttle it bogs down/no power..
Old Sep 27, 2008 | 01:33 PM
Ass$nyper's Avatar
please do snap a picture it'll let us know in a heart beat
Old Sep 27, 2008 | 04:18 PM
efjones9's Avatar
yea dnt think d15b is carb'd bt its dpfi. i made that same mistake
Old Sep 27, 2008 | 04:27 PM
Jimmy's Avatar
Global Moderator
alright here's the pic:
I bought this car not running.. put some plugs in it.. and shot a little starting fluid and viola.. running car..
Now as for the issues i can only drive 3/4 throttle or less.. if you go full throttle.. it bogs out and dies or just bogs.. no power..
i played around with the vaccum lines and it seemed to make a little bit of difference in how the car runs, but i don't have a diagram to go off of..
any ideas would be greatly appeiciated...
Old Sep 27, 2008 | 04:31 PM
Ass$nyper's Avatar
Default Re: (Jimmy)
That's DPFI sir.
Hondas used side draft carbs, there should be 2 fuel injectors on it.
Old Sep 27, 2008 | 04:34 PM
Jimmy's Avatar
Global Moderator
Default Re: (***$nyper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ***$nyper &raquo;</TD></TR><TR><TD CLASS="quote">That's DPFI sir.
Hondas used side draft carbs, there should be 2 fuel injectors on it.</TD></TR></TABLE>
Any ideas on my issue..
thanks bro
Old Sep 27, 2008 | 04:43 PM
Ass$nyper's Avatar
Default Re: (Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">
thanks bro</TD></TR></TABLE>sent via pm, also I'm pretty sure in the FAQ there is vacuum diagrams.
Check both injectors and timing first also look at your plugs.
Old Sep 27, 2008 | 04:46 PM
ya start by checking the timing
Old Sep 27, 2008 | 06:06 PM
shaggyeg6si's Avatar
Go on over to honda-hookup, sign up for their forums, and you can get any and all honda models factory shop manuals.
Old Sep 27, 2008 | 06:41 PM
88efZ6's Avatar
Default Re: (Jimmy)
tb gasket possibly?
Old Sep 30, 2008 | 02:27 PM
Jimmy's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ***$nyper &raquo;</TD></TR><TR><TD CLASS="quote">sent via pm, also I'm pretty sure in the FAQ there is vacuum diagrams.
Check both injectors and timing first also look at your plugs. </TD></TR></TABLE>
Looked in the faq.. didn't find any..
anyone have a vacuum diagram?
also to the right of the TB is what looks like an idle air control valve.. it's got a **** on it.. what does that do?
Old Oct 1, 2008 | 12:56 PM
Jimmy's Avatar
Global Moderator
bump for help!
Old Oct 1, 2008 | 02:37 PM
Jimmy's Avatar
Global Moderator
Ok i found the vaccum diagram:
My question is on #21.. at the end of it.. does it have to ''T'' off like in the pic.. cause the car is missing the piece it plugs into.. (the part on the firewall)
stackz
Nov 21, 2006 09:22 AM
RBaluca.com
Sep 25, 2006 01:53 PM
turtles_civic
Apr 2, 2006 12:21 PM
Doh!
13
Jul 24, 2004 06:31 AM
NobodysHero
Mar 28, 2004 09:03 PM
