reading codes on obd1 ef
Old Sep 27, 2008 | 11:18 AM
thedudefromjerz's Avatar
Default reading codes on obd1 ef
My ef is obd1 with a b18 motor inside. Im trying to figure out how to read codes off the ecu. Ive tried jumping the 2 wire plug by the ecu but no help. Anybody got any info ?
Old Sep 27, 2008 | 11:26 AM
ef92b's Avatar
Default Re: reading codes on obd1 ef (thedudefromjerz)
is your CEL on at least to begin with?
does your CEL goes off after few seconds when key on/engine off?
Old Sep 27, 2008 | 11:32 AM
HOODLOVER's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thedudefromjerz &raquo;</TD></TR><TR><TD CLASS="quote">My ef is obd1 with a b18 motor inside. Im trying to figure out how to read codes off the ecu. Ive tried jumping the 2 wire plug by the ecu but no help. Anybody got any info ?</TD></TR></TABLE>
i dont think those are the right wires..if you bought a conv. harness there should two wires that connect to be able to read the cel
Old Sep 27, 2008 | 11:34 AM
D16SiHatch's Avatar
Default Re: reading codes on obd1 ef (HOODLOVER)
i believe you can ground d4 on the ecu harness and it will start spillin codes.
Old Sep 27, 2008 | 11:35 AM
Default Re: reading codes on obd1 ef (ef92b)
the cel light is not continuosly on but after driving for a while it comes on so i would like to know why.
Old Sep 27, 2008 | 11:42 AM
HOODLOVER's Avatar
Default Re: reading codes on obd1 ef (D16SiHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16SiHatch &raquo;</TD></TR><TR><TD CLASS="quote">i believe you can ground d4 on the ecu harness and it will start spillin codes.</TD></TR></TABLE>
sounds right
Old Sep 27, 2008 | 11:44 AM
dacrxguy's Avatar
this is an intermediate code
every time u turn off the car does the code go away?
Old Sep 27, 2008 | 01:06 PM
Default Re: (dacrxguy)
yes it does but will usually come back. whats an intermediate code?
Old Sep 27, 2008 | 04:53 PM
gearhead16's Avatar
Default Re: (thedudefromjerz)
yes your correct ground wire d4 and turn on the key and your mil on your dash will flash
Old Sep 28, 2008 | 06:14 AM
slywfbpsi's Avatar
Default Re: (gearhead16)
yeah the conversion jumper kit that I bought didn't come with the jumper harness for reading codes. We just cut the plug from another engine harness (the plug that in the actual engine compartment) and solder it to the d4. then I just jump that plug if I want to read a code.
Old Sep 28, 2008 | 03:53 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (slywfbpsi)
if you are using a rywire harness, then i believe the extra blue and orange wires are the 2 you can wind together to see the CEL in the dash.
I recently swapped a car for a friend, and i wired a toggle switch to those 2 wires, so you just flip the switch to see the CEL. much less drama than using the old jumper harness and jumper pin, and cleaner than winding the 2 wires together all the time.
kcvi3tstyl3
Apr 20, 2009 06:17 PM
CeeJayy
Jul 27, 2007 07:48 PM
DieMaster
May 12, 2006 06:49 PM
JaHnAbOi
Oct 3, 2004 06:54 PM
Deetz
15
May 27, 2004 05:30 PM
