Issues with my new OMNI TPS sensor
So i got a new 65mm TB and a new TPS sensor to go with it and if I'm driving really slowly or consistently around 2k rpm my TPS will bounce between 12% and 8%, even though the TPS itself is set to 10% when the TB is completely closed. Does anyone else have any issues like me or recommendations?
bump for this tps issue. My car keeps jerking really bad. I don't see how i could ever install a TPS wrong so....
I think we've had similar issues as well. The TPS signal jumps up and down from 0% to 100% coasting down after a pass. We're trying to switch to an OEM TPS.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC »</TD></TR><TR><TD CLASS="quote">I think we've had similar issues as well. The TPS signal jumps up and down from 0% to 100% coasting down after a pass. We're trying to switch to an OEM TPS.</TD></TR></TABLE>
Yeah, when i see you have problems then i know it's official.
Hey, did you ever get those DIY tranny pics that you put on here at one point? I only bug you again cause I have EVERY SINGLE good DIY saved on my harddrive for integras or civics, except yours
