Transmission & Drivetrain Gearboxes, Differentials, Clutches
98 spec?
Old Sep 27, 2008 | 10:55 AM
killerpenguin21's Avatar
Default 98 spec?
other than meaning its out of a 1998 itr...what does this mean?
basically im looking to know the differences between a 98 itr trans and a 01 gsr trans, as i have the opportunity to pick up a 98 gearset with 4.7fd.
im just unsure about it it will fit, since even mfactory list a ton of stuff that wont fit a 98 spec, etc.
any insight is greatly appreciated.
Old Sep 27, 2008 | 11:13 AM
Aquafina's Avatar
JDM 98+ ITR 4/5 is the same as USDM GSR. Only the 3rd is the same as the ITR. Must use the JDM 1st gear to use the JDM FD. Not 100% sure about ring gear fitment so I won't say anything.
Old Sep 27, 2008 | 05:26 PM
Default Re: (Aquafina)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina &raquo;</TD></TR><TR><TD CLASS="quote">JDM 98+ ITR 4/5 is the same as USDM GSR. Only the 3rd is the same as the ITR.</TD></TR></TABLE>
so wait whats the same, is 4/5 the same or 3rd? my main confusion now is if the jdm countershaft is needed to run the jdm FD?
also i know you deal with mfactory a ton...do you know if the 3.07 first gear will work with the jdm fd? my guess is no....
Old Sep 27, 2008 | 05:34 PM
Aquafina's Avatar
4/5 are the same as GSR.
Countershaft is needed. Final drive consists of the ring gear and countershaft. 3.07 1st gear will not work with the JDM FD.
Old Sep 27, 2008 | 05:37 PM
ok thanks thats what i figured.
just_dung
Northwest (Sales)
19
May 3, 2011 06:22 AM
Rishiras
Nov 9, 2010 03:44 PM
killerpenguin21
Feb 13, 2008 06:29 AM
akteamster
Oct 16, 2005 09:11 AM
Jowee
Feb 24, 2005 01:48 PM
