b18a1 bearing tolerances
Old Sep 26, 2008 | 08:10 PM
seldon's Avatar
Default b18a1 bearing tolerances
hi, i did some searching and could not find an answer to my quetion, i got king bearings, could some 1 please tell me what the rod and main bearing tolerances are for a b18a1?
Old Sep 26, 2008 | 10:08 PM
wascly's Avatar
Default Re: b18a1 bearing tolerances (seldon)
If you are gonna be doing any kind of engine assembly, get a Helms or at least a Haynes manual for all of your tolerance ranges and tq specs. You will find the bearing clearance specs on the block and crank. It is different for every motor.
All Main Journals except 3:
Standard 0.0009 to 0.0017 inch with a service limit of 0.002 inch max
Main Journal 3
Standard 0.0012 to 0.0019 inch with a service limit of 0.0024 inch max
______________________________
Rod Bearing Clearance
Standard 0.0008 to 0.0015 inch with a service limit of 0.002 inch max
Who makes King Bearings, and what size (color) are they supposed to be?
I used OEM color coded bearings on my mains and ended up having to tighten up one size on Journal #5.
I used ACL bearings on my Rods and that worked out perfectly because I had my rods resized after having ARP bolts pressed in.
aliabdeen
Motorcycles
Nov 21, 2017 07:42 PM
Quetzolcotl
Feb 17, 2017 02:50 AM
pcguy760
Oct 4, 2011 10:16 PM
ltho1998
Jul 16, 2003 11:13 AM
t
Oct 4, 2001 09:20 PM
