xenocron 3 bar and TE
im sure very few of you guys still use turboedit but maybe you can help me out.
im debating on ordering a xenocron 3 bar map sensor, is turboedit compatible or is it set for only the gm 3 bar or does it not make any difference and im just being a wuss?
same goes for uberdata?
From: the asshole of america..., upstate new york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AJxr »</TD></TR><TR><TD CLASS="quote">im sure very few of you guys still use turboedit but maybe you can help me out.
same goes for uberdata?</TD></TR></TABLE>
your just being a wuss...
TE has stock, 2.5, 3 & 4 bar support. ecucontrol is setup with formulas for motorola sensors...not sure what the gm map sensor formulas are.
not sure about uberdata...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AJxr »</TD></TR><TR><TD CLASS="quote">so there is no calibration needed to run a motorola 3 bar with TE? only need to calibrate when using ecucontrol?</TD></TR></TABLE>
if you use the newest ecucontrol plugin...there is no need to calibrate anything...the motorola formulas are the only ones used (besides stock).
newest version of TE (with 4 bar support)
http://forum.pgmfi.org/viewtopic.php?f=60&t=15233
newest version of ecucontrol plugin
http://forum.pgmfi.org/viewtopic.php?f=60&t=14776
alright, i got TE 3.1.8 going here, definately a lot better. i was actually using TE 2.5.2 talk about stone age.
ok got everything going, gonna go try it in my car and see whats up.
next stage... getting my lc1 to work with it hah.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AJxr »</TD></TR><TR><TD CLASS="quote">alright, i got TE 3.1.8 going here, definately a lot better. i was actually using TE 2.5.2 talk about stone age.
next stage... getting my lc1 to work with it hah.</TD></TR></TABLE>
great!
fyi...you can log the lc1 signal digitally (throught the serial or usb/serial adapter) or with the analog voltage (through the nbo2 sensor pin) with the newest ecucontrol plugin.
let me know if you have issues, or it it works for you!
great!
im having troubles with a GM 3 bar and turbo edit. as fastcrx mentioned it uses settings from a motorola 3 bar not the GM 3 bar...
so anyone with a GM 3 bar and TE chime in.
im getting a CEL without ECU codes around -16.39inHg.
RACEPAK
Jul 23, 2006 02:32 PM
