k-pro & emissions
Old Sep 26, 2008 | 05:11 AM
weaponx12's Avatar
Default k-pro & emissions
i have a 96 civic and i'm planing on doing a k20 swap if i use k-pro would i be able to pass my obd2 emissions test ???
Old Sep 26, 2008 | 10:01 AM
Tomdata's Avatar
Default Re: k-pro & emissions (weaponx12)
that depends on what state you are in.
Old Oct 6, 2008 | 05:31 AM
weaponx12's Avatar
Default Re: k-pro & emissions (Tomdata)
I live in virginia
Old Oct 6, 2008 | 06:47 PM
Tomdata's Avatar
I am not too up on the requirments in Virginia. But as long as you only have to pass an OBD2 scantool test you should be fine as long as your OBD2 connector on your car is wired up to the KPRO properly and you don't have the OBD2 disabled in the KPRO. You can disable whatever codes you want and still pass the scan tool test you just cannot have the OBD2 completely disabled.
BTW you should be able to pass a tailpipe emissions test too as long as you have closed loop enabled in the KPRO and you have a catalytic converter on the car.
If there is a visual test in Virginia then you are SOL my friend.
Old Oct 7, 2008 | 04:33 AM
weaponx12's Avatar
Thanks for the info. Here in va we do the scan test so i just wanted to know if it would pass that way I had a obd1 ecu and i didn't pass now I want to do a k24/20 swap and just wanted to make sure it will work for my daily driver.
raverx3m
Jul 19, 2015 03:32 PM
csulliva
Jan 16, 2008 03:59 PM
-1TSXer-
Aug 1, 2004 07:25 AM
jolt-tsp
Oct 14, 2003 12:43 PM
MeanGreenEG9
Dec 4, 2002 11:16 PM
