My Type R setup need yor opinions
Old Sep 25, 2008 | 10:20 PM
Moi_DC2's Avatar
Default My Type R setup need yor opinions
what do you think about my set up... the gas in my country its too bad and this is my daily drive car i got this set up
Block
B18c Type R
P73 00 81.25mm (new Pistons and Rings)
Head
Port and Polish
Hytech Replica
JUN Type 1
Int-265 dur. / 10.9mm lift
Exh-268 dur. / 10.0mm lift
Aem Sprockets
Fuel Regulator
It will be Tune on crome after i do my break in session.
tanks 4 ur time.
Old Sep 25, 2008 | 10:56 PM
UncleD's Avatar
Default Re: My Type R setup need yor opinions (Moi_DC2)
What octane is available to you? Who is doing the headwork? What is the motor used for, and desired rpm range?
Old Sep 26, 2008 | 12:17 AM
Moi_DC2's Avatar
Default Re: My Type R setup need yor opinions (clean rice)
91 premium
My head work is do it by Alxis de Moya my mechanic and tunner
And it is for Drag Racing
Old Sep 26, 2008 | 01:28 AM
UncleD's Avatar
You have a ton of different options. If being used for drag racing, the M22x is going to be extremely hard to beat. But BC4/S2S2/S2 Pro1/Jun3/Blox B or C would all work for you. There is no "best," all of the above will give you results...but not all will yield quality/longevity. Use adequate VT.
4drsedaneg
Welding / Fabrication
11
Mar 1, 2009 06:26 PM
wrestler72
Feb 28, 2007 09:30 AM
eboR
Jul 7, 2004 06:47 PM
jowy
Nov 18, 2003 06:15 PM
XViEtBoiX
17
Jun 20, 2003 04:37 PM
