professional wire harness job pricing?
to replace harnesses my motors been swapped but not the harnesses so i need them to put in the new harness for my swapped motor
i have the motor in my car already jus set up with the wrong harness and i wanted to replace wit another set of harness that i already have in hand and i wanted to kno how much it would be to replace the wire harnesses in my motor
why dont you just go get a civic ex harness cause the engine harness goes directly yo the ecu just get the harness out of the same year
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solattack77 »</TD></TR><TR><TD CLASS="quote">why not just buy a new one from honda or the cheaper way from majestic</TD></TR></TABLE>
HAHAHA they're sooooo expensive.
You don't need an entire new harness, or really anything else, you can just get a plug for the vtec solenoid/oil pressure switch/whatever else, and you can either connect it to the ecu pinouts where they go, or you can take the engine harness off your car, put your new one in where the last one came off (on either side of the firewall, the three fat plugs on the left and the two fat plugs on the right) and just reconnect it all to your motor. But you'll probably still need to attach the vtec wires to the ECU, so you might as well wire it from the vtec/oil press to the ecu.
kodamoose420
Nov 13, 2013 03:10 AM
