92-95 corner light fitment issue..
Old Sep 25, 2008 | 01:00 PM
Weak!EG's Avatar
Default 92-95 corner light fitment issue..
in the process of re-assembling my hatch and having trouble getting the new corner lights to fit.. the headlamps fit no problems, but the corner light is a totally different shape even than the fender..
at first i thought it was bc they are 4dr corners, but i borrowed a 4dr one off a friends car and it fit even worse..
here are a couple of pics for reference. the fenders are stock, and the corners are jdm oem clears... please help!!
Old Sep 25, 2008 | 01:04 PM
Redline it.'s Avatar
Default Re: 92-95 corner light fitment issue.. (Weak!EG)
u sure its not sliding in right into the guide next to the headlight or the studs going into the holes in the fender?? i think your fender is not oem...if it is than it must have been damaged before or not repaired correctly.
Old Sep 25, 2008 | 01:07 PM
Weak!EG's Avatar
Default Re: 92-95 corner light fitment issue.. (Redline it.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline it. &raquo;</TD></TR><TR><TD CLASS="quote">u sure its not sliding in right into the guide next to the headlight or the studs going into the holes in the fender?? i think your fender is not oem...if it is than they mustve been damaged before of not repaired correctly.</TD></TR></TABLE>
yes, it is securely slid into the guide piece on the headlight, and i broke the tabs off the corner light to see if that was an issue..
if you look closely the corer is touching the fender at the bottom and top but the curve of the fender and the curve of the corner light are totally different..
and the fenders are 100% oem, they were on the car before the respray..
Old Sep 25, 2008 | 01:11 PM
Declectic's Avatar
LOL judging by the pictures.... it looks like the passenger side corner light is what you are trying to fit on the driver side
in another words, it's upside down and on the wrong side of the car
again, just what it looks like to me from the pictures
Old Sep 25, 2008 | 01:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Weak!EG &raquo;</TD></TR><TR><TD CLASS="quote">
..</TD></TR></TABLE>
u need those tabs for the corner lens to stay in place and fit right. have u tried putting back on the stock corner..and see how that fits??
Old Sep 25, 2008 | 01:14 PM
Weak!EG's Avatar
u need those tabs for the corner lens to stay in place and fit right. have u tried putting back on the stock corner..and see how that fits?? </TD></TR></TABLE>
i know you need the tabs.. but i was so frustrated i was willing to do anything to help it even close to fit..
and i cant find ANYONE here with a hatch or coupe to let me use a corner for 30 seconds..
edit: my stock corners went away over a year ago with the other stuff off the car lol
Old Sep 25, 2008 | 01:21 PM
Weak!EG's Avatar
you can see in this pic, even the crappy ebay light that came with the car had a better fitment
Old Sep 25, 2008 | 02:13 PM
Declectic's Avatar
again, looks upside. are those corners replicas or OEM?
in the pic u have, there are the smaller vertical lines (much closer together and not as tall), they are in the top on your pic
in this pic below, those smaller lines are on the bottom, only reason why i say i think it maybe upside and could possibly explain why you had to break the tabs in ur frustration
here is another pic, hard to tell
Modified by Declectic at 3:20 PM 9/25/2008
Modified by Declectic at 3:21 PM 9/25/2008
Old Sep 25, 2008 | 02:20 PM
Default Re: 92-95 corner light fitment issue.. (Declectic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Declectic &raquo;</TD></TR><TR><TD CLASS="quote">again, looks upside
i dont think it is. the longer straighter part is on the bottom.
Old Sep 25, 2008 | 02:23 PM
Declectic's Avatar
i dont think it is. the longer straighter part is on the bottom.</TD></TR></TABLE>
guess your right, finally found a pic
oh well, guess it's just shitty fitment on the corners he has
Old Sep 25, 2008 | 02:25 PM
from both pics i think its 4dr. the shape is different compared to the coupe.
Old Sep 25, 2008 | 02:29 PM
Declectic's Avatar
here are some four doors
Old Sep 25, 2008 | 02:43 PM
randomtask77's Avatar
Unbolt your headlight, then assmble the cornerlight/headlight combo and test fit it.
Old Sep 25, 2008 | 02:46 PM
kojack_0's Avatar
Default Re: 92-95 corner light fitment issue.. (randomtask77)
maybe you have 4dr fenders?
Old Sep 25, 2008 | 02:50 PM
redlinexd's Avatar
crap... i hope the cornerlights i bought from ebay dont look like the one u shown as an example. take a look here
http://cgi.ebay.com/ebaymotors...11850
Old Sep 25, 2008 | 03:27 PM
sh!tsWEAK!'s Avatar
Default Re: 92-95 corner light fitment issue.. (kojack_0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kojack_0 &raquo;</TD></TR><TR><TD CLASS="quote">maybe you have 4dr fenders?
Hmm..Braxton this might be it. There's no way for the fitment to be that off with all parts being oem, so something is not right. I know that some guys with 4dr's are able to rock 2dr/3rd front bumpers without any real fitment issues, so maybe whoever had your car before you put 4dr fenders and 4dr amber corners on it? Does the passenger side have the same fitment problems?
Old Sep 25, 2008 | 03:53 PM
Weak!EG's Avatar
Default Re: 92-95 corner light fitment issue.. (sh!tsWEAK!)
i have a 4dr corner set in my storage and they fit TWICE as horrible as these... but they are ebay 4dr corners.. maybe the oem 4dr ones fit bad just not as bad..
i guess ill order a new set of 2dr stanley clears off ebay and hope they fit
Old Sep 25, 2008 | 04:11 PM
redlinexd's Avatar
woot! just got it 5 mins ago from UPS!@!
Modified by redlinexd at 5:46 PM 9/25/2008
Old Sep 28, 2008 | 08:30 AM
Weak!EG's Avatar
Default Re: (redlinexd)
took a better pic and used the passenger side outside in the light..
the tabs are in the fender and as you can see, there is no way its even close to fitting properly..
Old Sep 29, 2008 | 12:59 AM
soup06's Avatar
not saying that your wrong. but
i believe those are 4dr.
maybe jdm 4dr.. idk
but that is clearly not right.
k20rex
Lighting
Jul 2, 2010 01:55 PM
danielfleenor
Nov 16, 2009 11:53 AM
sageuvagony
Jun 30, 2008 04:13 PM
turbointegrar
Oct 6, 2006 08:33 AM
sniggler316
Jul 17, 2006 12:32 AM
