Axle Issues - H22 in Ej6
I bought this car in June, and being that I love slammed EK's I bought some Ground control coilovers to use with the Koni's that were already on the car. I installed the fronts, didn't get to the rears just yet, But when the car is really low I get this vibration from the axles. Almost like a cv joint going out. I had to raise the car up in order to rid the vibration. Is there anyway to alleviate this? I really want to slam the car they way i intended.
I had a tranny issue, so i swapped the tranny, and the tech that did the swap said that there were some wrong bolts in the axles??? Would this possibly be part of the problem? I haven't had the time to crawl under the car just yet, so any help or insight would be awesome!
did you mix brands? didnt read post however if you use (for example) hasport mounts then you HAVE TOO use hasport axles. same with innovates or avids. you cannot mix and match, you will have axle binding if you do so
I didn't do the swap so I am not sure what was done. I think its all OEM. So there is hope? Anyone else? Can i get custom axles made?
93civicjaydm
Oct 25, 2006 07:05 AM
