b18c1 block upgrade?
i want to know what kind of stuff i need to upgrade my block and also pass smog like camshaft,rods,pistons,rings, etc.
i heard that it wont pass smog if you put other than stock on the block but im not sure
help me out!
thanks!
help me out!
thanks!
well sorry but im not gonna do the rebuilt
i just needed to know if i upgrade to bigger and stronger ones will it pass smog?
or should i just upgrade to all type r etc since its is oem specs
Look at the links I posted in this thread
https://honda-tech.com/zerothread/2394704
actually, spend $50 on amazon and buy a couple books on rebuilding motors and honda hot rodding. if you are that new, get a couple books that explain how a 4 stroke engine operates, how cams & compression work in synch etc..
the Search button is your best bet. you seem to know nothing. so goto how stuff works and research online. I was once like u and didn't know much, now i build big tubro A4's S4's WRx Hondas etc just for the hell of it. replaced my engine last weekend, you'll get there. If your lookin to "upgrade" u need to know what u want to do.... N/a boost etc.... looking for a litte more power out of your b18c1.... intake exhaust..... Rebuild? theres alot to learn but easy too all the info is there.as for smog I know theres alot of CA honda guys that can help u.
HondaEm1-00
28
Feb 26, 2014 05:22 PM
